Question about Cameras
The screen is black and the sound does not work but the green light is on at the top. it will not turn off if i hold down the power button
  • Cameras Master
  • 17,129 Answers
Failure of the control board which can be due to many reasons.
Since the processor is not enabling any of the display / ccd or the serrvo of the camera, the errror steps in to hang off.
Consult the makers service centre.
Posted on Sep 16, 2010
  • Cameras Master
  • 4,924 Answers
Try to remove the batteries and the card ...After that insert only the batteries and turn it on ...if it works it is a block-age from the card that might be either damaged or need formatting ..
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    Ds lite flashes on but fuses are ok
    One or both your screens have blown.
    Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
    Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
    If this happens the problem is then you're top screen which you will have to replace.
    Jul 26, 2009 | Nintendo DS Lite Console
    My screen is black
    hit FUNCTION and usually F5 button. Look for the keyboard key with the "monitor" icon. If not hold power button down and power the laptop down. Wait 10 seconds and reboot.
    May 25, 2009 | HP Compaq nx6110 Notebook
    Lcd monitor power light flashing with no img. seems 2 be frozen
    The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
    If the serial number begins with an A and/or your power button on the far right (5th button from left):
    Method #1
    1. Unplug the VGA cable.
    2. Remove the power cable from the back of the monitor.
    3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
    4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
    5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
    Method #2
    4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
    If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
    Method #1
    3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
    Method #2
    3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
    If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
    Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
    No black ink
    Canon S330 Turn off printer
    Hold down Resume button and press Power button.
    Keep holding down Power button and let Resume button go.
    Press Resume button 2 times then let BOTH buttons go.
    Green lights will flash and then stop blinking.
    When green lights are solid, press the Resume button 4 times.
    Press the Power button and the printer should turn off, if not, press the Power button once more.
    Your printer should respond as normal
    Nov 22, 2008 | Canon S 330 InkJet Printer
    Ps3's green light turns on usually screen stay's black
    Call Sony so they can fix it. This sounds like multiple problems. Good luck.
    Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
    Open Questions:
    Cameras Logo
    27 people viewed this question
    Top Cameras Experts
    Steve
    Are you a Camera Expert? Answer questions, earn points and help others
