Question about Boating
1977 Johnson outboard motor 70 hp runs fine for about 20-30 min. but once it heats up the motor slows down to where it doesn't make a wake and sounds like its not getting enough fuel.....whats going on/could it be an ignition coil? Thanks Jeanie
    Top Expert:
  • Boating Master
  • 51,548 Answers
Sounds like you have a cooling isue . might need a new water pump or impeller.
Posted on Nov 02, 2010
1983 9.9 evinrude runs good on land but will not accelerate under load.
This happened to mine, I found out the gas lines were going bad and restricting the flow of gas
Apr 02, 2017 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
The cover says evinrude triumph 70, the #317219 is on the head, the boat is a 1977. no where does it say johnson. where do i find any kind of info. on this 3 cylinder motor?
if you go google and type in evinrude you will see numerous references to johnson outboards , evinrude/johnson inferring that they are using interchangeable parts or are in fact the same outboard made in different countries
May 28, 2016 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
My 1977 85 hp Johnson motor will trim up but not down. I traced the wires from the trim switch to the solenoid and all are hot. I replaced the solenoid but it still will not work. I can cross out t
2 solinoides , one for up and one for down !!!! test trim switch then try swopping up solinoide to the down and problem could be solved !? check wires !
Jul 31, 2014 | Sierra Outboard Starter for...
Does a 1977 Evinrude 70 horsepower engine hav a charging system?
The 70s Johnson or Evinrude outboards of similar sizes did not have any charging system. I had an old Johnson 50HP (key injection) mounted on an 18Ft Zodiac and I needed to remove and recharge the battery once every couple of weeks. Keep the battery dry and the contacts well greased.
Apr 25, 2011 | Clymer EvinrudeJohnson Outboard Shop...
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Boating Logo
374 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
