Question about OKI C5200n Laser Printer
I have windows vista and I finally downloaded the driver C5200ne now I tried to print a test page and I get an ERROR message in control panel/printer. What is wrong? It just seems like it's a software issue. Any help would be great
  • OKI Master
  • 17,130 Answers
Make sure that you had unistalled all relative software in the PC, remove the printer and uninstall the present software. Now reinstall the software and once it finishes connect the printer to be detected and installed.
Now take a test print. If there are errors , it can be fault in the printer.
Posted on Sep 16, 2010
  • 4,924 Answers
If you are sure that you have the right printer ..go to device manager (right click on my computer ..properties..../hardware ..device manager ) and look for the printer ...and if it is in yellow with an ask sign on it ..,click right on the device (printer ) and choose update driver ..and run the wizard and follow what it says at the final before ..finish ..
if it says the a problem was on ..and the device wasn't installed proper ...it means that you do not have the right driver and you need to download it again from the support site ..and run it into computer ..(but not before removing the old one completely and be sure that you got read of all traces of it ..)
http://my.okidata.com/pp-C5200n.nsf/openingdrivermenu?OpenFrameSet
follow the exact instructions on that page ...and be sure you selected the operation system correctly
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
May 27, 2010 | Dell 725 InkJet Printer
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Goodluck,
Please don't forget to rate the solution.
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
I got a new computer and tryed to hook up my okidata c5200ne printer to it(old comp had xp new onw had vista) and install the driver for okidata website and run the driver but it would finish and wouldn't...
if you downloaded the right driver for it ..it has to work ...be sure that you have the driver for vista operating system ...and be sure that is for the kind of vista you run ...(meaning on 32 or 64 depends on which one you use)
as I already took a look they are available on the manufacturer site ..(okidata)
Aug 01, 2009 | OKI C5200ne Led Printer
HP Laserjet 1160 and Vista
Download update from HP on Vista.
Jul 11, 2009 | HP LaserJet 1160 Printer
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
I have installed cannon pixma ip 2600 on my vista and it will not print says an error occured
Hallo
Some time ago I helped I friend with a simular problem, a Canon printer and Windows Vista. An error message came up when trying to install the printer driver. I looked through the windows register using regedit.exe and deleted all occurancies of Canon. (Be careful when doing this) . After doing so I restarted the PC, downloaded a fresh driver (by saving it to disk), doubleclicked to unpack it and finally installed. This might help you. Good luck!
effander
Jan 12, 2009 | Office Equipment & Supplies
Vista
Re: Vista and Print Server check out a reply from 2006 at:
I need HP Printer Driver for Vista - DriverHeaven.net
gave hint to use hp deskjet 5400 driver instead of the hp business inkjet 2230 driver i have been trying for days with my Netgear PS101 print server (v1?). Finally works, at least for a complete looking test page and the preferences for the 5400 printer seem clearer than those given for the 2230. maybe that is why print servers and printers are not working...it is the driver supplied by HP is wacko for vista?
Jul 12, 2008 | HP Business Inkjet 2230 Printer
Driver for printer epl 5900l with os vista
In Win7.Ultimate.x86 ver 7600.16385.090713-1255, go to the Control Panel->View devices and printers, right click on “Epson EPL-5900L Advanced”, select printer properties, click “OK”, select advanced, set “print direcfly to the printer”.
It worked!
Mar 16, 2008 | Office Equipment & Supplies
OKI C5200n Laser Printer Logo
62 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
