Question about Acer Aspire One PC Notebook
Jarring sound when starting up or playing certain audio Also running very slowly.
    President:
  • 2,291 Answers
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 16, 2010
Me tv Lg have issue when Im Washing tv audio Work but Some time image off and Sound i can hear.
This sounds like either a bad connector that is jarring loose on the video side or you are intermittently losing signal. Audio will go out before video on a bad signal. It requires more bandwidth.
Feb 05, 2016 | LG Televison & Video
I play drums, and when playing with my QC15's on certain loud sounds seem to make the noise cancellation clip and cut out audio for a second. why is it doing this?
Does this problem only happen on when playing drums? For me, when my battery is running low, if I move my head back and forth quickly or lightly tap the right headphone, they will clip in and out briefly, but replacing the battery always fixes this. My guess is that you are playing drums a lot, your battery is running low, and you might be throwing your head around violently, causing a similar problem.
Feb 15, 2011 | Bose QC15 Headphones
I have the Acer AspireOne. I suddenly started getting sound distortion on songs played in itunes--it skips then plays really slowly and with a mechanical type sound to it. I thougt there was a problem with...
I have the exact same problem with my acer aspire one. Just recently is started distorting with a mechanical sound...skipping on the videos and making it impossible to actually listen to anything or watch any videos. I thought it might just be an isolated problem until i noticed it happening during startup, etc. I have not found a solution yet but am updating the audio driver. Let me know if you resolved this issue! Thanks!
Sep 10, 2010 | Acer (54.AA806.001) Sound Card
I play my music on low and it has bass wen i turn the radio up it starts hiting only certain bass notes the lowest dont hit hard it starts sounding weird???? i have it hooked to a audiobahn aw1206t...
sounds like you have some wires crossed. check your radio setting and make sure that the subs are only playing bass and no trebble. buy some new rcas
Mar 10, 2010 | Nitro BMW-486 Car Audio Amplifier
Windows 7 makes an annoying noise about every 5-10 minutes. like its letting me know im afk or something this is terribly annoying as im trying to sleep and such can i turn it off? what is it? ...
Windows 7 is an OS which has lots of upgradation done from the existing Windows XP and other versions and runs on longhorn and Vista principles. If you have a problem with annoying noise, it will be appreciable if you can give a clear picture on what noise it makes... is it a beep, or a jarring music, a fan speeding noise, or any Wav file played from its system audio files.
If it a fan speed increasing with loud noise, please check the compatibility of your Hardware with the OS. May be you have to update your BIOS to clear this out and most of the HW Drivers.
If its some audio file played, check for tracking down the file which is played and understand which program is initializing it by just looking at the backend process running and the threads utilized.
If its a noise which is neither a beep or a system Audio played and just a horrible sound from the speakers... Please check the HW ports for Audio by taking the Laptop \ Desktop to a HW engineer after updating the Audio Drivers. This will resolve your
Issue i believe. Do write back if you need any further assistance. Good Luck.
Feb 15, 2010 | Microsoft Computers & Internet
Cd turntable does not turn without jarring the whole unit - therefore, cd's do not play
Sounds like the little motor inside the cd turntable keeps sticking, i have seen electronic motor do that from time to time, it might be worth having a go at pinching the side around the motor to try to loosen it a bit or completly changing it out.
Jan 16, 2010 | Audio Players & Recorders
Laptop Logs and Hangs when playing FIFA2008
Hi
My Name is Simon,
Just Upgrade the laptop RAM to 1 GB.
Aug 03, 2009 | Intel Frontier Design Dakota 24-Bit PCI...
Sound distorted at start-up and when program starts
Try going to dell and down loading an upto date sound driver and see if that clears up your problem. If not, you have an internal problem with your sound device.
Good Luck
Fehdi
Mar 26, 2009 | Dell Dimension E510 PC Desktop
External speakers do not play
It is not an issue with the speakers or the sound card as you get sound in media player and also while playing cd's.
It could be the volume settings on the player tht the websites use to play the audio or the video,
Jan 30, 2008 | Neovo E-19A 19" LCD Monitor
Audios & Videos brings scratching sound !!!
try installing the graphics driver. this problem occurs due to the driver. try installing the driver given with the motherboard.
Sep 24, 2007 | Intel D845GRG Motherboard
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
