Question about Brinkmann Temperature Gauge
The gauge is stuck at 300 - Brinkmann Temperature Gauge
  • 111 Answers
You may try reheating the grill to see if you can free it. If not you will have to replace it.
Posted on Sep 17, 2010
Testimonial: "thank you"
Why if i put the fuel full the gauge fuel stucking only in Half?
Because sending unit reads whats reads.Could be expensive to fix the best drive 300 km and refill, what I am doing now.,
Aug 05, 2017 | Cars & Trucks
Temp/gauge not reaching normal working temp-richer
the first thing to check is to feel if the radiator is hot, if the radiator feels hot and the engine is also hot the coolant is circulating ok then the problem is more than likely electrical, the temp gauge gets its signal from the engine control module the coolant temp sensor sends coolant temp signal to engine control module for engine managment purposes then passes it to instument pack/gauge, if the sensor was at fault you would have engine running problems also,with poss fault codes logged, if the engine and rad are cold/only warm after the engine has been run for 15 mins or so it sounds like the thermostat is stuck open but you have changed that. i have had faulty new ones in the past and have had to test them in a pan of boiling water, hope this is some help to you.
Apr 02, 2015 | 2006 Jaguar X-Type 2.0
My 2006 300c starts sluggish and won't stay cranked; then the red gas light and the engine light stayed on. Now it won't crank at all.
Could be many things. Best would be to read codes for a hint. Stuck EGR, leaky fuel injectors, bad fuel pump (test with pressure gauge), bad coolant temp sender, bad crank sensor, bad ignition module/coil, others also.
Dec 28, 2014 | 2006 Chrysler 300
Temperature control not working properly
It could be ur thermostate, that was happening to my 94 lexus es300, and the gasket was stuck in thermostate preventing it from opening up all the way, that or ur heater core needs to get flushed, what temp does ur gauge say inside the car?
Oct 07, 2012 | 1994 Lexus Es 300
My 2002 lexus 300 gas gauge is stuck on full. HELP
you will have to take the sender unit out and renew it dont think you can do a lot with it as i think it may have stuck to the ceramic plate that has the carbon path on it ,but you never knoe take it out and have a play
Oct 14, 2010 | Lexus ES 300 Cars & Trucks
The fuel gauge is stuck on empty what can be done to fix the issue?
If the gauge is stuck on empty there is a good chance that the float came off of the sending unit inside the tank. If you have a trip meter on your car you can use that as a gas gauge, just remember to zero it each time you fill the tank. I don't know how far your car will travel on a tank of gas but, I would think you should be able to go 200 to 300 miles. Carry a gallon of gas in the trunk too, you may have to experiment a little.
Jan 23, 2010 | Mitsubishi Galant Cars & Trucks
Low oil pressure light is on on 2000 lexus rx300. Doesn't need oil or an oil change. Not leaking oil.
try replacing the oil preasure switch, if that doesnt solve your problem then have your oil preasure tested, if it really doesnt have oil preasure it will cause internal engine damage so start with the switch and then go from there, hope this is helpful.
Nov 29, 2009 | 2000 Lexus RX 300
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
My 2004 grand cherokee overland oil pressure gauge does not regis
must be oil in engine after 300 miles and it did not seize up,check elect. connection at oil pressure sending unit,if ok,check unit itself!
Mar 19, 2009 | 2004 Jeep Grand Cherokee
Brinkmann Temperature Gauge Logo
112 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
