Question about Carrier 38CKC036 Air Conditioner
38ckb024320 relay bad fan not coming on - Carrier 38CKC036 Air Conditioner
Why wont my fans on my 1993 chevy lumina come on after i changer the radiator?
There are fan relays that sense the coolant temperature and cycle on/off based on temperature. Some cars have 2 radiator fans. If the fans do not come on it's probably a bad relay. The relay/fuse panel is normally under the hood. Check your owners manual for the actual relay location
Aug 18, 2014 | Dryers
Where is the radiator cooling fan relay on a 2006 Sonata 3.3L?
The relay in engine compartment fuse box.
For its exact location and wiring diagram,click the link below:----Hyundai Sonata cooling fan not working http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
---------------This will help.Thanks.
Feb 26, 2012 | 2006 Hyundai Sonata
My cooling fan will not come on car overheats at slow speeds
4 things possibly....fan motor, relay, Temp sensor, or wiring. If you are electrically savvy, jumper the battery directly to the fan to see if it runs, to rule out a bad fan motor. The relay may be bad, and there should be a box full of various relays under the hood. You may be able to swap the fan relay with another known good relay to see if that fixes it. If you are really cheap, and the fan motor is good, just wire it so it comes on when the ignition is on. I did this on an old Escort once, and it worked just fine.
Jun 19, 2011 | Ford Taurus Cars & Trucks
Coolant fan will not come on, regardless of the temp
You may have a bad fan switch if you can find the temp sensor and unplug it the fans should come on but your temp gauge want work but it will get you some air until you find the bad switch. Hope this helped
May 30, 2011 | 1994 Chevrolet Cavalier
96 honda civic cooling fan is not coming on. The fuse is good. Could it be the relay?
If the fuse is good, it could very well be the relay. To check the relay, remove the relay from plug and use a piece of wire stripped on both ends. Insert the wire into the plug and touch each plug to see if fan comes on. If fan comes ion after testing with wire, then the relay is bad. If fan does not come one, then the fan motor is bad.
Feb 16, 2010 | Honda Civic Cars & Trucks
My car overheats can't find the fan relay. help where is it?
Does it only overheat while sitting? Then the fan motor or relay could be bad. Just follow the fan motor wiring. It is probably in the relay block center.
The fans do not come on when car is in motion. Then thermostat is bad or coolant is bad or water is bad.
Oct 01, 2009 | 1988 Pontiac Grand Am
1996 Chevy Cavalier fan not coming on
Check youre fan relay's and fuses. they may be bad or going bad. The fans are not continuous fans either they only come on when needed. But if the relay or fuse are bad it will not start.
Aug 26, 2009 | 1996 Chevrolet Cavalier
I have a Rheem Model # RAMB-030JAZ that the fan will not come on when the A/C is turned on and does not produce cold air. Is there a common electrical problem for this model that would prevent it from...
The unit has a fan relay that sometimes goes bad. Check to see of fan is hot or tryimg to start. Might be bad capacitor. Fan relay or relay boards are easy to change.Russ
Jul 30, 2009 | Heating & Cooling
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
92 eldorado coolant fans dont come on
the fans have relays that are located in the fuse box under the hood on the driver side. a quick check involves just switching the a/c clutch relay with the fan relay if they turn on when engine is hot the relay is bad. if not that means there is a bad connection or the temp probe is bad. make sure no loose or frayed wires are present. hope this helps. please rate this solution. thank you.
Aug 29, 2008 | 1999 Cadillac Eldorado
Carrier 38CKC036 Air Conditioner Logo
124 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
