Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Frezzer won't freze bad smell just befor it quilt
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Hi, thanks for visiting FixYa.com! The most common failure is going to be the compressor relay, located...well, on the compressor. It will likely be square and white in color. After unplugging the refrig, you can pull this little relay off and shake it. If it rattles, it is bad. Look for any discoloration or burnt wires as well. If bad, replace with new one from www.appliancezone.com and you should be good to go!
Posted on Sep 16, 2010
Stitches too small
TIP: A general rule of thumb is that if the stitch looks bad on the top it is the bottom tension.
If the stitch looks bad on the bottom it is the upper tension. The upper and lower threads play
tug of war with each other.
Tension
You need correct tension on the top and bottom threads, but you must also have correct tension on
the quilt held between the rails. You should have a small amount of "sag" in your fabric. This allows
enough movement of your quilt layers for the needle to penetrate and make good stitches.
Before you start making adjustments to your machine ask yourself, "What changed?" If your machine
was stitching great and all of a sudden it has loopies on the back or puckers, "What changed?" Did
you just change the bobbin? Did you just lift the take up rail? Did you lower the take up rail after
finishing your last quilt? Did you recently change the needle? Did you just roll the quilt?
If the take up rail with the quilted portion of your quilt is too high, it will result in poor stitch quality. You
need a finger tip space between the quilt and the machine bed. Higher will result in poor stitch
quality, too low and the quilt will create a drag on your machine's movement.
Look at your bobbin, a sloppy wound bobbin will not create a good stitch. Make sure that the threads
on the bobbin are snug and evenly wound. Check to see if there is a piece of lint in the bobbin case
Dec 19, 2016 | Sewing Machines
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
Refigerator cool but frezzer don,t frezes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 22, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Burns yellow and has an exhaust smell/Not propane but an ezhaust smell that gives me a head ache and sore throat. I need an answer now as it is frezing and snowing.I have no heat. It is a lp wall unit.
The burner could be blocked the air ports are clogged lack of air to burner casing to burn yellow, or you haveproblems with you reg , ie low pressure, It sounds like its giving off fumes , needs to be looked at by a gas fitter asap.
Feb 27, 2011 | Williams 18065119 (LP) Gas Heater
Freezer is not frezing foods, I can smell a gas like odor
sounds like your freezer is leaking freon.may not be any easy or cheap fix.are there any cracks on the inside of the freezer?
Jan 17, 2010 | Westinghouse Refrigerators
Freezer works fridge doesnt?
most likely defrost problem . most refrigerators getting their cold air from the freezer, so if your frezzer frost up, no air gets to fridge side, u have to remove the frezzer panel and inspect the evaporator coil, if frosty, u have bad defrost system, which part is bad? depends on the brand and model.
Oct 31, 2009 | Dometic RM2852 Refrigerator
Constance condensation on the frezzer department. Had GE service and all he did was warm up the rubber seal on the ice despenser door. But it still frezes up. There is no sign of condensation by the ice...
condensation in the compartment indicates that the door seal is not sealing properly or the door needs adjustment
it is from moisture in the air coming out of the air as the temperature cools the air down inside the compartment
problems that cause that are -:
opening the door too often
humidity levels high in the room
door seals faulty
not enough insulation in the door would only mean that the compressor is running more often or constantly but will have no affect on the condensation problem
Oct 12, 2017 | GE GSS25KGPBB / GSS25KGPCC / GSS25KGPWW...
My kenmore 1 8.2 cf refrigerator doesn't work ,the fan too but the light is on in down compartment (is a top frezzer refrigerator).thanks.
is your freezer frezing or nothing works if the compressor is not running you can install a 3 in one relay to see if your compressor is gould this only cost about 15.00 dollars if your compressor is running then make sure the fan in running
Dec 05, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Whirlpool ice maker water line frezees in the frezzer section.
  • usually when this happens the water valve is slowly leaking water. this small amount of water will freeze inside the fill tube for the icemaker; eventually blocking the water flow.
  • you might need to change your water valve going to your icemaker.
Jul 04, 2008 | Whirlpool Refrigerators
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
