Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
My headst is fully charged but will not turn on. Have used the headset recently, so it was paired with my phone. have green light but when i depress the MFB nothing happens, no sound, and no lights change.
SOURCE: Motorola H700 pairing
I had this problem and found you need to open the mouthpiece soon after the lights goes violet, otherwise the light starts to flash blue and you are too late and its time to start again.
Posted on May 26, 2007
SOURCE: Can not remember how to pair my nokia bh208 headst
Try this:
Pair the headset
1. Ensure that your phone is switched on and the headset is
switched off.
2. Press and hold the power key until the green indicator light
starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone
to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing.
You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the
phone menu where you can view the currently paired Bluetooth
devices. The headset is now ready to use.
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-208_APAC_UG_EN.pdf
Posted on Mar 03, 2009
jazzbassist
  • 4 Answers
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Posted on Dec 16, 2009
Testimonial: "This worked perfectly! Thanks!"
  • 91 Answers
SOURCE: I cannot get headset to
when turning on your bluetooth device hold the power button down,for 8 to 10 seconds this usually puts the bluetooth inn pairing mode,then you have to enter a pin pairing code ,motorola and most other bluetooth manufactures use a 4 digit pin pairing code,motorola is as follows 0000,1234, and the others incase they dont work,are 9999,1111,try them in that order hope this helps
Posted on Mar 23, 2011
  • 6771 Answers
SOURCE: Headset indicates fully charged (green
The rechargeable battery is bad and needs to be replaced.
Posted on May 18, 2011
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
The phone says that no dvice can be found
it will be like the headset is paired with another phone previously. so you need to unpair that first.
turn on, turn off and turn on while holding the ON button along with the volume up button. it will blink and when the light will show up continuously, the unpairing is complete.
now search for the bluetooth from mobile and pair. i guess you know the password. ...... the default pasword for all headstes will be 0000 which you have to input from mobile when prompted
Aug 14, 2009 | Jabra Bluetooth Headset with Adjustable...
Try this:
Pair the headset
switched off.
Mar 03, 2009 | Nokia Bluetooth Headset Headset
CABLE & WIRELESS CWBTH160
To initiate pairing, put the devices within 0.5m of eachother
Make sure phone / pc bluetooth is on and discoverable
Make surea headset is fully charged
  1. Ensure headset is switched OFF
  2. Press and hold the talk button (big central button on front of headset) until the indicator flashes red & green alternately, then release. Headset now ready for pairing.
    Note: Headset pairing mode will time out after 5 mins.
  3. To allow phone / pc to "find" the headset, consult your phone / pc bluetooth operating guide on pairing devices.
  4. Headset should be listed on phone / pc after search has finished - highlight and select the headset.
  5. A pin or password screen will appear, you must enter 0000 and confirm.
  6. When pairing is successful, headset indicator will change to green and flash continuously every 3 seconds.
Pairing is then complete.
Note: Multi-pairing.
It is possible to pair up to two phones with the headset - the most recently paired phone becomes the "primary "phone... only one phone can be connected at a time --> this function only works in Hands-Free profile. If both phones are in range, then the headset will connect to the "primary" phone first.
Apr 09, 2008 | Radio Communications
Pairing
Make sure both are in pairing mode. Then try it again.
Sep 23, 2007 | Motorola Mobility HS850 Consumer Headset
My Phone Does Not Locate My HS820 Headset
Try the following:
1) Make sure the HS820 is fully charged up.
2) Remove the battery and SIM card from your phone for about 1 minute and put them back in.
3) As soon as your phone is booted up, access the "find devices" function for adding your HS820.
4) Hold the HS820 button down until the blue light is solid.
5) Then do whatever your phone requres to "search for devices."
6) Here's the key: as the phone is searching for devices, PHYSICALLY TOUCH touch the HS820 to the phone.
I couldn't get my HS820 to synch with my new Blackberry Curve the normal way and ultimately got it to synch by going through this process.
Sep 11, 2007 | Motorola Mobility HS820 Consumer Headset
H700 Headset
Is the Samsung bluetooth turned on?
Jul 17, 2007 | Motorola Mobility H700 Wireless Headset
Connected then Disconnected!!!
that could mean your headset is not charging. make sure the light is doing what it is supposed to when charging. you probably have a defective charger. happened to me. you could try pairing it with another phone to see how long it lasts. I found the Moto HS850 to be the only good, reliable one.
Jul 09, 2007 | Motorola Mobility H500 Wireless Headset
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
18 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
