Question about Ovens
I have a Omega stainless steel oven model 00651XN 60 x 60 I am finding it difficult to clean the glass oven door as it seems to want cleaning between the two glasses and I see no way of getting inside to clean it. Could you please give me some advice as to how I can do this. - Thanks Regards Linda Smith
  • 883 Answers
SOURCE: Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Posted on Jun 02, 2007
SOURCE: Removal of door
get a special key and open
Posted on Nov 13, 2007
SOURCE: Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Posted on Aug 13, 2008
SOURCE: Door Face needed (Glass broke, model discontinued, can't get part)
Linda, if you can't find a replacement door at local used appliance repair shops - check the Yellow Pages - look to see how the door comes apart.  It is probably held together with 6 or 8 Philips screws.  Get the door apart and take out the broken glass.  Call around to see if an appliance repair store has an oven they are discarding that has the same size glass or larger.  If the glass is too big, phone a few glass shops to see if they can 'cut' it down for you.  Some tempered glasses can be cut and sanded down to the precise size you need. Take your old broken glass to the shop to be used as a template. You should be able to get away with this type of repair for $50 if you compare prices. Cheers, Pavel
Posted on Oct 21, 2008
  • 17 Answers
SOURCE: cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Posted on Feb 04, 2009
I have Omega wall oven model 00652xb 6yrs old, there are dribble marks in between the glass in the door. How do I clean it. I can't see how it comes apart. Thanks
The oven glass is a sealed double pane. it is not designed for removal, separation, cleaning, and reassembly.
May 12, 2016 | Ovens
How to clean the inside glass of themador PODMW301
you have to remove the door and disassemble the whole thing.
I do them all the time.
Feb 16, 2014 | Thermador Professional Series PO301...
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
How do i clean inside my delonghi glass door the inside
if you pull the oven out a little bit and look under the the door there should be 3 screws you only need two undo one on each side but when undoing the last screw hold the bottom of the door tight as it will fall when you have door frunt off job done ok
Oct 12, 2012 | DeLonghi DEBIE24SS Stainless Steel...
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
HI I HAVE A SMEG OVEN MODEL NUMBER SA995XR I NEED THE INSTRUCTRION MANUAL JUST TO SEE HOW TO WORK THE SELF CLEANING OPTION THANKS
Hi I have just installed this oven SA995XR-5 yesterday and have the manual. It doesn't say anywhere it is self-cleaning, just good old elbow grease. Below is what is in the manual.
*I have a question for you. Does the cooling fan in your oven go all the time or does it stop some time after the oven has been turned off (which is what the manual indicates it is supposed to do)?
7.Cleaning and Maintenance
Before performing any operations requiring access to powere parts, switch off the power supply to the machine.
7.1 Cleaning stainless steel
To keep Stainless stell in good condition it should be cleaned regularly after use. Let it cool first.
7.1.1 Ordinary Daily Cleaning
To clean and preserve the stainless steel surfaces always use only specific products that do not contain abrasives or chlorine-based acids.
How to use: pour the product on a damp cloth and wipe the surface, rinse thoroughly and dry with a soft cloth or deerskin.
7.1.2 Food stains or residues
Do not use metallic sponges or shapr scrapers: they will damage the surface.
Use normal non-abrasive products for steel and a wooden or plastic tool if necessary.
Do not allow residues of suraty foods (suc as jam) to set inside the oven. If left ot set for too long, they might damage the enamel lining of the oven.
7.2 Cleaning of the oven
To best oven upkeep clean regularly after having allowed to cool, Take out all removable parts
  • Clean the oven grill and side guides with hot water and non-abrasiev detergent, Rinse and dry.
  • The oven should be operated at the maximum temperature for about 15/20 minuytes after using specific products, to eliminate the residue deposited inside the oven.
  • For easier cleaning, the door can be removed.(8.2)
7.3 Door Glass
The door glass should always be kept clean. Use absorbent kitchen paper to clean. In case of tough spots, clean with a damp sponge using regular detergent.
8.2 Removing
Hold the door on both sides with both hands near hinges (A - there is a diagram showing this is the top hinge) and raise levers (B - this lever is a little arm attached to bottom hinge. Flick it up until it catches into groove on upper hinge. Its quite uncomplicated). Lift up the door forming an angle of about 45 degrees and remove. To refit, slide the hinges A in the grooves, drop door and release levers B.
8.3 Oven door seal
To permit thorough cleaning of the oven, the seal may be removed. Before the seal, take off the door as described above. Once the door has been taken off, left the tabs at the corners as shown in the figure.
After cleaning, refit the seal with the longer side horizontal and insert the tabs into the appropriate holes starting from the top ones.
Jan 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Glass oven door
We Use DeBruce Polish on all our cooktops. DeBruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Oct 27, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Ovens Logo
152 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
