Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
No water comes in the washer when turned on. Can here something running and the dryer heat comes on.
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 18, 2010
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
Water coming out front of condenser
It is difficult for me to understand why any water should be coming from the dryer. Your washer maybe the fault, clothes should be, at best, damp from the washer with very little excess moisture. Check to see if your clothes washer is spinning, if necessary try turning off the water supply to the washer and run another rinse/spin cycle, if your clothes are still wet or dripping then your washer needs repair. Check that first... And report back
Jan 21, 2013 | Hotpoint TDC32 Electric Dryer
My dryer is Tcm570 it started leaking water on the floor while clothes are drying, then not drying after circulation. But if I try to put it on now it turns all the power in the house off. What's
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Jan 12, 2013 | Dryers
Whirlpool Duet Dryer Tripping Breaker on Heat Cycle
It caused the problem. Appliance repair person
May 13, 2017 | Whirlpool Dryers
Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
Instructions
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
Feb 24, 2011 | GE Dryers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water leak from washer
The element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Whirlpool Thin Twin Model LT7000XUNO stack unit
ithink I have the lt7000xuno
something got jamed in it now the drum won't turn mabe spun abelt or is there a cut off switch?
Aug 05, 2008 | Whirlpool LTE6234D Top Load Stacked...
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
60 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
