Question about Poulan Pro 18 Inch 400E Chain Saw
I HAVE A POULAN PRO 400E ELECTRIC CHAIN SAW, TODAY IT JUST QUIT WORKING, DOESNT SMELL BURNED, HAVE ELECTRIC TO IT. CUT THE FIRST POST AND WHEN I CUT THE SECONAD ONE IT JUST QUIT. WHATS UP , HATE TO TRASH IT. ITS ALMOST NEW, WAS WORKING FINE, OIL IS FULL.
I have the same problem --if any one knows please send info
Thanks Ron
Posted on Dec 28, 2010
My poulan pro pp400e chain stops on cut,and the motor still runs
So the chain stops and the motor still runs. Does it run at high RMP or just idles. It could be the chain brake. My clutch froze up on me after an hour of running. I had to let it cool and then take it apart to free it up.
Jun 17, 2011 | Poulan Pro 18 Inch 400E Chain Saw
My 18" Poulan is awsome,
When it overheats it may not be getting enoiugh oil. The oiler may be weak have it checked. I too, have a Poulan 18" Chainsaw and I think it is great. Everything I own is Poulan Pro or Troy Bilt. They are simply the best for the price.
Dec 15, 2010 | Poulan Pro 18 Inch 400E Chain Saw
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
My Poulan E300 Electric Chainsaw stop oiling the chain and bar
Hello JK; I am hesitant to answer this, these are all Poulan electric chainsaws that appear when the parts source is searched for Poulan Electric Chain Saws:
400E Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400E-Poulan-Pro-Electric-Saw/75.400E-Poulan-Pro-Electric-Saw.1.59.1.html
400EX Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400EX-Poulan-Pro-Electric-Saw/75.400EX-Poulan-Pro-Electric-Saw.1.59.1.html
ES400 Electric Saw
http://www.ordertree.com/modelinfo/PWE/ES400-Electric-Saw/75.ES400-Electric-Saw.1.59.1.html
PP250E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP250E-Electric-Saw/75.PP250E-Electric-Saw.1.59.1.html
PP300E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP300E-Electric-Saw/75.PP300E-Electric-Saw.1.59.1.html
All are plumbed the same to my eye. I assume you cleaned and tested the oil pick-up within the tank. If everything you say is true if the pump is driven it should oil.
1. What causes the pump to pump? I cannot tell from the IPLs. If gas and not gear driven, an impulse line (pressure/vacuum) from the crankcase drives it. There can be no impulse line on an electric and I see no gear. Does it rotate to pump oil? What imparts the rotation?
2. What purpose does item 27 (pinion) serve? Is it supposed to drive the pump? Is it missing teeth?
3. What is the purpose of item 44 (check valve). If it is an oil tank vent, and not opening, you are creating a vacuum in the tank if the pump is operating. Loosen the oil cap and see if it oils. If yes replace the check valve.
I think Joe Schmoe is saying Poulan redesigned the oil system to eliminate all the hose couplings. It makes sense, one hose from oil pickup (filter on hose end in tank) to bar is much less likely to leak, also no restrictions for any particles in the hose to form a clot on. I see nothing on my research to support Poulan doing that. There are a couple of new models that I cannot find an IPL for so it is possible. I have headache JK. If this does not solve it is not because I did not give it my all. Please post back (below) with success or failure. If successful what was the cause. TIA
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 29, 2010 | Poulan Pro Chain Saw 46cc 20"
What is the proper way to sharpen the chain
you can buy a simple kit for a few dollars, there is a jig that holds the chain and a roud file that will be guided through the jig at the proper angle to sharpen the chain
Oct 31, 2009 | Poulan Pro 18 Inch 400E Chain Saw
Electric Poulan Pro 400E won't run. Can't turn chain manually or turn chain sprocket either. Feels stuck and won't budge.
Loosen the chain as it could have run over something or tightened itself as the chain dried out. But if it won't turn and it just humms or does' nothing the motor may have overheated and locked up. The motor may smell burnt ( like a hot elecrric stove) and it may be melted together. If its halfway new and you have the reciept you can try to exchange it but certain kinds of failures may not let you get an exchange
Sep 04, 2009 | Poulan Pro 18 Inch 400E Chain Saw
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan Pro PP3516AVX chain saw. I used it
Their not the best saws but make sure the nuts holding the bar and cover on are tight after adjusting chain sometimes improper cutting will continue to kick chain off bar.
Mar 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 18 Inch 400E Chain Saw Logo
245 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
