Question about Sony BRAVIA KDL-46V3000 Television
46 sony bravia Lcd tv on a articulating wall mount Whats a Good hight floor to bottom of the tv
Hello,trying to figure out the right hight,from floor to the bottom of the t.v. where it will look right in the room,without being to high? T.V.is 29"h x 44.7w
ok here's the details:
Room 12ft.w x 14ftL ---With 7ft.9in.Celling
Tv will go on the 12ft.w x 7ft.9in.h Wall With the Artickulating Wall mount.
I have a Entertainment center there now thats 42" high.
I want to put the tv at 45" from floor to botom of tv.
Do you think this is a good hight for this tv in this size room??
I just don't want it to high,so I don't have to give out neck braces :)
Any input on this would be awesome.Thankyou in advance.
  • Dave Segala May 18, 2008
    Is there anyone there? I managed to get the cabnet down a bit,so the
    bottom of the LCD TV is at 42 in.off the floor. Thats as low as I can
    get it.I hope that's ok,for viewing this TV.
  • Dave Segala Aug 09, 2008
    Thankyou; Managed to get it at 42" on a articulating wall mount.Apsolutely Awesome! Perfect Hight.
The ideal height would be between 38" and 42". with your stand being 42" high I would say 45" would be fine. Anything over 50" off the floor will put strain on your neck and give you constant headaches after watching for extended periods of time.
Posted on Aug 08, 2008
Kdl 40ex400 logo come own then color bars
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
How to attach wall mount to a Sony Bravia 32" TV
You need to be careful here. Unless you are very handy, the TV could come crashing down to the floor if not done correctly. Depending on how much you paid for the TV, I would hire a trained individual to do this.
Oct 20, 2014 | Sony BRAVIA KDL-32BX330 32" LCD TV...
My Sony KDL-42EX440 will not turn on
Have you tried to do a "reset" ALL modern electronic items often get "locked up" and unplugging them from the wall will often get them going again. Unplug for at LEAST 30 seconds--then try again. If this does not help--the SMPS board may have failed on you. A good repair shop may be able to repair the board instead of replace it.
May 06, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
The word debug is on the screen. how do i take it off?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
Feb 27, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Backlight failure on sony kdl-55hx729
That usually has to be replaced by a service tech. Contact the manufacturer.
Dec 14, 2012 | Sony Bravia KDL-55HX729 LED Internet TV...
Cant get the table stand off the bottom of my tv!
There's four screws that hold it in place, two on either side of the television, that attach to the arms that hold the base.
You need to unscrew those, and then slide the tv up off the top of the stand's arms.
Mar 15, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA  KDL-46V3000 Television Logo
129 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
