Question about GE Zoneline Deluxe Series Cooling & Electric Heat Unit AZ25E07D3B
Ge ptac throws gfci
Unit throws the gfci button on the plug when the ac in on . . . accumilates a lot of water, excessive water. . . temperature controls are real flakey . . . we have been changing from amana to ge for about 2 years, (we have about 55 ge units out of 115) and our first ge units are beginning to drop out. I have had three ge units with the same problem in the last week. I have others that the temperature control seems to have no effect.
Should these units be under a warranty? If I work on them will it negate any warranty?
If I work on them where should I start??
  • 828 Answers
If the units are worked on by someone who is not GE approved service tech, yes it can void your warranty. If these units are not properly installed it could be why you have excess moisture. A slight tilt toward the rear of the unit gives better moisture drainage to the outside.
Posted on May 17, 2008
Trip reset when plug in
Either your household wiring has inverted hot/neutral or no ground connection, or the GFCI plug on the air conditioner is defective and needs to be replaced. Either way, you have some work to do: Using a circuit test plug (available everywhere inexpensively), verify that there is not a wiring issue with the outlet, and rewire the outlet as necessary. Once wiring is verified, if the GFCI plug on the air conditioner still trips, just replace the GFCI plug end, and done.
May 21, 2015 | GE Zoneline In Wall Ptac Unit Air...
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
F21 code displayed> cleaned water trap next to water pump that had lots of stuff plugging the filter but now power cord GFCI plug shuts off when I try to Start washer...
Hi you could have a clogged drain pump or obstruction in it. Remove the lower bottom cover. Have a container or towels to catch water. Removed the drain cover by turning counter clock wise. Sometimes you have to remove the pump to fully and clean. You also need to plug the washer into another outlet. If possible use an extension cord use the extension for test only.
Apr 25, 2014 | Whirlpool Duet WFW9550 Front Load Washer...
The gfci tripswhen i turn my ptac to heat what is my problem?
The gfci is short for the ground fault circuit interrupter. This prevents voltage from the hot side of your AC circuit to feed through to the case. This would mean somewhere within, a wire may be touching the frame. You should not try to live with this situation. One quick check might be to reverse the plug in the receptacle. If this does NOT cause the GFIC to trip, then the short must be found and insulated with electrician's tape.
Oct 04, 2013 | GE Zoneline AZ55H07D Air Conditioner
I have an Amana ptac hotel type thru the wall unit. The unit won't turn on - it's plugged in. The gfi button is popped out. There is power to the wall plug. Any ideas?
If you reset the GFCI button and then when you go to turn it on the button pops again, then you have a short inside the units probably in the fan motor or the compressor..
heatman101
May 14, 2011 | Amana PTH123B25AJ Heat Pump Air...
Two brand news ac unit out of box will not work
get a yellow tester from homedepot, it has three lights [ amber amber red ] hat tell you what you have at the plug. takes out all the guess work. you will love
good luck
saw
Jul 09, 2009 | Heating & Cooling
Charging a ptac unit?
Full service both coils first ,add your filter, then add a line temperature probe in the supply air flow or on the line going to the compressor add freon till you get the lowest temperature nad then it will start to climb, you've had the correct charge,!
Sep 08, 2008 | GE Zoneline AZ55H07D Air Conditioner
Have a ge ac in window unit asto5 model leaks inside just recently . connot find any plug to pull for draining outside excess water inside ac cabnit . does it have one? been running this ac all summer and...
No drain plug but this model should have a SLINGER RING AROUND the end of the fan blades which picks up the water & sling it on the back coil which it is so hot & evaporates to help get rid of excess water .. So as for the water running inside, the drain channel are plugging up, from the front coil to the back, & only need to add clorox bleach to the front coil area for now , to kill the slime or mold slowly blocking the channels..But first, TURN_OFF UNIT! (certain times of the year, mold & slime grows rapidily and thats what the bleach for..!
Sep 05, 2008 | GE Heating & Cooling
PTAC UNIT QUIT WORKING
If you have a clamp tester, operate the unit with the clamp tester and check the current reading. If the current reading is normal but the reset button is tipped then there is something wrong withe power plug reset button. But if the current reading is higher than the name plate rating then there is something wrong with the unit.
Mar 09, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
179 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
