Question about Acer Aspire 5920-6423 Notebook
My acer aspire 5920-6423 wont charge or turn on. the adapter is new and the light on my laptop wont even turn on.
    Problem Solver:
  • 26 Answers
We provide products of good rate for the shoppers and try to make a large client base. Please feel free to have a look around and contact us when you have any questions. Our company is a maker representative and distributor of compatible consumer electronics replacement, especially of notebook components: CPU Cooling fan~ Inverter~ power jack; Camcorder Battery Charger , power tools battery, and other products.For more information: =====http://www.2egoo.com ======= Thank you! Jonly $$$$$$$$$$Toshiba Satellite A200-23H Power Jack Selling price 8.91========
Posted on May 04, 2012
  • 526 Answers
First, try it without the battery, on rare instances, the battery shorts out the unit, otherwise you have a bad power distribution board which most likely is part of the mainboard.
Posted on Sep 16, 2010
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
My Acer Aspire 5735 doesnt turn on
try on the laptop without battery plug in, if still didn't work, you need to get a adapter replacement for your laptop
Dec 06, 2013 | Acer Aspire 5735 Notebook
How come my acer aspire one note book wont turn on at all and its plugd int it wont even show its chargeing
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on the bottomof the adapter. If the voltage is zero or way below the voltage that is printedon the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 21, 2011 | Acer Aspire One PC Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Acer aspire one D150-1Bw battery not charging
the battery is gone dude. This year manufactures have reduced the quality of batteries drastically to cut down the costs and i think u got even the worst of them.
and whats more they they dont even give warranty on batteries for more than 6 months.
so U'll have to get new one. Sorry
Jan 05, 2010 | Acer Aspire One PC Notebook
Acer aspire 4930 wont turn on
If the power LED on the Notebook is blinking but not turning ON then the issue is related to the power supply unit and service is required.
Nov 03, 2009 | Acer Aspire 4930-6862 Laptop
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
Ac adapter connection inside laptop doesnt work, light for battery charging will not turn on and will not charge
You adapter may be faulty, check it with a multi-meter, the voltage reading for a functioning adapter should be slightly higher than the voltage that is printed on the label on the adapter.
If you do not get a voltage reading then the adapter is faulty and you need to get a replacement adapter.
If you get a reliable voltage reading at the adapter plug, then connect it into the laptop and wriggle this plug. If the charge LED blinks. then the power connector on the laptop is loose/faulty and needs repairing.
Apr 14, 2009 | Acer Aspire 5570-4820 Notebook
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5920-6423 Notebook Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
