Question about Canon Office Equipment & Supplies
Canon MX320 series Paper is not feeding straight
  • 526 Answers
Either the roller is worn out or dirt, and you may want to replace it or clean it, or you may have some foreign object in the printer that causing it to skew. you can try (CAREFULLY) to flip it up side down and see if anything falls out, other you will need to try the first 2 options.
Posted on Sep 16, 2010
The paper will not feed properly into my mx320 canon printer. It pulls the paper in on the left side but not the right side. I can see no paper stuck anywhere on the rollers. I have removed and replaced...
The mX320 being a rear sheet feeder model can suffer the problem of something falling into the feeder and causing the paper to jam on entry.
To find what has fallen in your will need to gently pull back the fed paper and look at its leading edge. This will show a heavy "Nick" in the edge. observe where the nick is in relation to where the paper is fed and that will indicate where the obstruction is in the feeder. Use a bent paper clip (L shaped) and see if you can feel and dislodge the culprit. Remove the ink cartridges and turn the machine upside down and give it a good shake. hopefull the drawing pin/paper clip/notice board pin will fall out and the world will be at peace once more.
Good luck.
Aug 07, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Everyone with canon pixma mx320 is having same problem where paper will feed in faster on one side and eventually give you a paper jam. why can't you guys put a solution for that?
I am a Canon engineer who actually works for canon and goes out in the field and repairs Canon equipment. I can assure you there is no problem of skewing in the paper feed of any of the current canon range. Paper skew is always down to the paper hitting an obstruction in the feed. Also if you are using paper of less than 80gsm in weight then skew can occurr. Most of us "Guys" offer this service totally free and make no money from Fixya. I am one.
When your machine jams, pull the paper back out SLOWLY and look for a "Nick" in the leading edge of the sheet. Place this back in the tray and you can now see where the obstruction will be because the nick will line up with the obstruction. Any money you like and you will find either a drawing pin (Usually a cork notice board is above and behind the machine on a wall) or a staple or paperclip will be jammed in the sheet feeder.
Good luck.
Jul 13, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Canon mx320...i dont have a document jam but error message keeps saying remove documnet from adf file and eject documnet..i have checked all of my connections and turned the power off and on ..removed...
on the top of your printer, the ADF section (Automatic Document Feeder) where the documents is feed to for faxing, check if there is a paper stuck in it.
or better open the ADFcover and examine a latch switch make sure it is standing up right.
Feb 28, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My canon mx320 says paper jam when there is clearly no paper jam. How can i make this stop or reset the printer?
I have a Canon MX320 and am getting the same error message. It appears as if one wheels that aids the paper is not turning? I would also appreciate any help concerning this issue.
Dec 18, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
When trying to print paper being pulled in at an angle so it jams
This means that there is paper stuck near the internal paper feed rollers. Look inside and remove any paper that you see. Then take a damp cloth and clean all the rollers you can see.
Nov 15, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon Mx320 printing error 5200.How do I fix it?
Just remove the ink cartridge from the printer and clean the surface contact using a cotton moistened dipped in an alcohol .
Return back the cartridge and try to print again.
Try also to Press and Hold the STOP/RESET button until printer restart. Release the button when to completely initialize the printer
Aug 20, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
288 people viewed this question
old marine
old marine
