Question about Rival Microwave Ovens
Can't set the clock on a Rival touch-pad 700- watt m/w oven - don't have an instruction manual.
  • m.e.stoltz Jul 24, 2012
    Rival don,t give answers to problems ,they are ****** products
  • Rival Master
  • 17,130 Answers
Log on to the main website of Rival , register you name and product , post your query for the manual.
Log on to:
www.rivalproducts.com
Posted on Sep 16, 2010
  • sashakr Sep 16, 2010
    That's what I did first. Microwaves are not on their Kitchen Appliances list
A time was set on the oven and it is the wrong time. i would like to change it.
Good afternoon Penny.
The manual for this microwave can be obtained/viewed here ( and have tips for all those other things like changing the scroll speed of the display )
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40536-1.pdf
If you go to to Page 24, the time set is a fairly common one:
  1. Press [Clock]
  2. Enter Time of Day with numeric keypad
  3. Press the [AM/PM/Scroll Speed] Button under the Zero key.
  4. Push [Clock] or [Start] to finish and set the time.
Cheers - hope this helps.
D
Dec 01, 2015 | GE Spacemaker JVM1740 1.7 cu. ft....
The Time and Memory Buttons stop working and function again a day or 2 latter why is this happening and can it be fixed?
1200 watt input and 700 output makes it 700 watt machine.
sounds like tThe touch pad is finicky . Yes , you are stuck with it unless you wish to replace the touckh pad.
They claim to have parts for Mezzo:
spares.bigwarehouse.com.au
Aug 03, 2014 | Microwave Ovens
After a power surge, the display comes on. Yet, the buttons do not work. Is there a button to reset?
Is this a one time event? Try unplugging the unit from the wall for at least one hour and plugging it back in. Open the door and close it. I'm not familiar with this particular model but I have to guess that you push the stop/reset button to set the clock after plugging it in. It may be a bad touch pad or a bad door sensing switch.
Sep 19, 2013 | Danby Designer Series DMW077BLSDD 0.7 cu....
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
How to set clock on asda microwave, p80d20al t5
1. Touch CLOCK pad.
2. Touch CANCEL pad.
3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
4. Touch CLOCK pad again.
Aug 31, 2010 | Microwave Ovens
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Setting the clock on Emerson MW 8115SS
Press Clock, press the numbers for hours & minutes, select with AM/PM pad, then press Clock again to set it.
Yours Emerson microwave owner's manual is available for free download here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
903 people viewed this question
Top Rival Microwave Ovens Experts
William Miller
William Miller
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Rival Microwave Oven Expert? Answer questions, earn points and help others
