Question about Denon Audio Players & Recorders
I have a denon DP-30 L II turntable. it has very low time the problem is the right channal is out. I have tried 4 differant cartridges. thay work fine on a yamaha YP-850. I have tried 2 differant mac amps thai I know are trouble free. CAN SOMEONE PLEASE GIGE ME SOME IDEAS. I am a licened aircaft tech but this is my weak aera electrisity and spelling
  • bryan4p May 17, 2008
    i have tried TWO DIMM MACINTOSH AMPS THE FIRST PERSON MUST BE TIRED
    I HAVE USED A 10 POWER BACKLIT SCOPE NORMALLY
    USED ON TURBIN ENGINS DONT SEE ANY BREAKS
    ITS UNPLUGED PLEASE EXPLAIN WHAT WILL RESET OR CLEAE OUT ??????
    THANKS FOR THE PROMPT REPLEYS
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
OK, here with some assistance from a long-time (30+ years) turntable expert. You will need an ohmeter to test the two relevant wires, and equipment to tear the turntable down. (This assumes you are comfortable performing these actions.) Further, as you have indicated that the solution posed by MarkDay did not help, it appears that these are not related and the problem does not lie with the amp connections. Therefore, this should tell you if you have a wiring issue.
Basically, within the tone arm, there is a set of two wires that run from where the wires are attached to the cartridge within the tone arm, through the tone arm and into the turntable itself. Within the turntable, they attach to a circuit board, and are likely sautered to the board. (They will be two different colors. However, breaks of the type previously described, will likely be difficult if not impossible to see due to protective coating.) What we will do is test the wires from the cartridge to the circuit board to determine if one (or which one) is bad. It appears this is the problem - with a high level of probability - and will then require replacement of the tone arm. However, no one wants to spend the money for a new arm if it's not necessary. So, here's how to figure that out:
The bottom of the turntable should be removed, using basic screwdriver / necessary tools, but being cautious with that tone arm connection. Remove the cartridge from the tone arm on the top side, if you haven't already done so. There will be two different color wires that attach from the tone arm above (cartridge connection), down into the circuit board. Place one end of the ohmeter at the tone arm end of one color wire. Place the other end of the ohmeter at the circuit board end. If the meter shows full current (all the way up) the wire is good. If not, the wire is bad. Then you will likely need to replace the tone arm, as attempting to replace wires within the arm itself is quite difficult.
Once you have that in hand, if wires are sautered to the circuit board, which we expect, it will require appropriate tools to break that connection safely ("unsauter"). "Unsauter" the old wires from the circuit board, and sauter replacements to the circuit board. Remember that the new wires will be part of a new tone arm assembly, and must be placed in a manner identical to the original assembly.
Hope this gets you to the point where you at least have narrowed down your issue and can work further on getting it going. If you need further assistance, please post back, and we'll be happy to help as needed - and thank you for rating FixYa!!
Posted on May 17, 2008
  • Cheryl Whalen May 18, 2008
    bryan4p:
    Wanted to check in with you to see if you have determined whether the cables / wires within the tonearm were the problem, or if we need to move further into a different direction. Please post back if we haven't yet isolated the issue. As you know, we can't "fix" a hardware problem, but if we can diagnose the issue and help to direct you to a solution, we have reached the goal. Look forward to hearing further from you - and if you have reached resolution, thanks for rating FixYa!
    smartsolve
  • 790 Answers
Hi
maybe you have defective preamp one side channel or the RCA wire is defective, you can replace a new one RCA wire then odserve!!!
    Genius:
  • 1,665 Answers
  • 2,322 Answers
Have you try the denon DP-30 L II turntable on a different amplifier?
Try to switch the turnable outputs and see if that works.
If the right channel still not working you might have a defective pre-amplifier input on your amplifier.
  • 111 Answers
Wire between cartridge (through tonearm) to rca jacks on back is most likely broken. Typical for this to happen at cartridge connector or at rca jack connector. Sometimes wire is broken within outer jacket making it practically invisible to see even with magnifying setup. A good audio/video repair shop should be able to repair this. Another possibility is faulty patchcord between turntable and preamp.
  • Mark Day
    Mark Day May 20, 2008
    Rewiring a tonearm is a delicate, fragile and tedious process. My original solution of having a qualified a/v shop do this still stands, Our shop carries parts for most major makes and models. BTW, smartsolve, its "Solder", and there are 4 wires, not 2.
    Genius:
  • 2,035 Answers
Please unplug the unit for 10 minutes and Try to set to factory mode and then use it .
Adjust pitch
Register (free) at Vinyl Engine and download the service manual. The adjustment you need to do seems fairly simple. You will need a turntable strobe disk to get the the speed right, unless you have perfect pitch.
http://www.vinylengine.com/library/denon/dp-29f.shtml
Jun 19, 2014 | Denon DP-29F Turntable
I need a cartridge for my Denon DP-DJ151 Turntable, and I can't find one anywhere. Is there a universal I could get? Thank you!
You can fit any cartridge as long as it will fit the headshell. Just look around for something like the Denon cartridge mount.
Sep 19, 2013 | Denon DP-DJ151 Turntable
Need cartridge for my denon dp-dj151 turntable
You can use any cartridge as long as it will fit on the headshell.
Replace cartridge stylus
Hi, my advise to customers is to buy the best quality audio gear you can afford. If you tell me your budget I will suggest a couple of carts that match. Cheers John. Styluscity
May 27, 2013 | Denon DP-26F Turntable
What cartridge to use on Denon DP-DJ151?
Anything that will fit the headshell. You can spend a few pounds or few hundred on them. It depends what kind of quality you want.
Dec 04, 2012 | Denon DP-DJ151 Turntable
I need a copy of DP-DJ151 owners manual
Do you really need a manual for that? All you need to is fit the cartridge to the headshell then connect the wires to it. If you don't know which of the wires is left or right, just connect it to a switched on amp then with your finger touch each wire one at a time. You should hear a loud buzz on the left on one wire and on the right on the other. The other two wires might buzz a little on there channels, but it doesn't matter as they are earths. The new cartridge will tell which are the channels on it and the earths.
May 26, 2012 | Denon DP-DJ151 Turntable
Which thickness setting should I use when playing my 33 rpm records on my Denon DP 297 fully automatic turntable? 17 or 30?
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Oct 22, 2011 | Denon DP-47F Turntable
Headshell for Denon DP-45F Turntable
The PCL-30 does not look like a standard headshell. I doubt the above answer is correct.
Aug 02, 2008 | Audio Players & Recorders
209 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
