Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I can not figure how to change the name of my wireless connection how do i do so?
  • 12,061 Answers
Hi, this is simple the name of the wifi connection is the SSID, you need to login to your router via a web browser, entering default, (Assuming it hasn't been changed, if so you need to press reset button at rear of unit to restore default,) login and password, and when you are IN the router, you go to the SSID section and make it anything you want, it doesn't matter.
Please go to this link below and download your user manual, it will show you how to login to the router, using default passwords, it also will show you how to change the SSID, (Or name of the WiFi Connection)
http://www.dlink.com/products/?pid=6
Posted on Sep 16, 2010
How to set up a internet password for a mac with net gear
  1. se an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    For Steps 4-9, refer to Figure A below.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  5. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  6. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrasebox.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  8. Click Apply to save the settings.
Mar 08, 2012 | Computers & Internet
I have a nieghbor who has somehow found out my password. How can I change my password so he can't use it anymore.
you can change your wireless encryption password by going to internet explorer
the default login/pass
  • Username = admin
  • Password = password
    • For older devices, password = 1234
if this does not work you will need to reset your router by holding the reset button for 30 seconds or more when you power it on.
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  3. When prompted for a Username and Password, enter the default username and password (admin;password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into thePassphrase box.
Mar 29, 2011 | NetGear MR814 Wireless Router
I want to connect to internet using this unit please help me
  • Figure 1
    The strongest local wireless network connection
    is displayed on the N95's Active standby screen. In this case the phone has found a network called 'mat'
  • Figure 2
    To search for more WLAN connections, click Options, highlight Search for WLAN and click Select
  • Figure 3
    To connect to a WLAN network, highlight its name and click Connect
  • Figure 4
    If the wireless network is security-protected, you'll need to enter its hexadecimal WEP key to log on
  • Figure 5
    You can also connect to a WLAN using the WLAN wizard. This can be found in the Tools are of the Main menu
  • Figure 6
    When opened, the WLAN wizard displays a list of the available local wireless networks. Highlight one and click Options to log on
Feb 28, 2011 | Nokia N95 Cellular Phone
I was on my ds and i went to Nintendo wi fi settings and it asked me to input my wep key and now i cant figure it out.
BELKIN ::::
Hi ,
By Default the security in the Belkin is WPA and unfortunately the DS Doesnt support this
To enable WEP in the Belkin follow the Steps Below
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Feb 13, 2011 | Belkin Basic Wireless Router
I have been unable to connect to the wireless. Linksys has changed the configuration to "N" and have gone thrugh several other options but still cannot connect. Kindle has not be able to...
The Kindle connects to WiFi networks supporting standards 802.11b and g. If your router is configured to use 802.11n exclusively, the Kindle cannot establish a connection. However, you should be able set up your router to "mixed" mode or "b+g+n operation".
The exact procedure and naming of the option depends on your router's model name. If you cannot figure it out yourself, feel free to add a comment to this solution, providing the model name and version of your LinkSys router, and I'll probably be able to give you further advice.
I
Jan 28, 2011 | Amazon Kindle Wireless Reading Device
Im trying to figure out my wpa key for ps3
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK "
TO CHANGE THE PASSWORD :
Step 10 : on the left under wireless click Channel and SSID
Nov 28, 2010 | Belkin F5D7234-4 Router
Change my settings from wep to wpa I have a belkin 54g
when you change the wireless security on the router , it is recommended tht you will change the wireless network name also ( SSID ). Because when you try to connect to the wireless network on the computer, your computer will try to connect to the same old network name with the old wireless security settings. To avoid this you can change the wireless network name. WPA is supported by windows XP SP2 and above operating system.
If the operating system on your computer WINDOWS XP SP1 and if you are trying to connect using the windows utility then you would not be able to connect to the network .
Click Here for more information about the routers and networking
Jan 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
2WIRE wireless router
While changing the name,its not in wireless router.
!.switch off the wireless router.
2.first change the name of the PC.(don't connect to wireless)its normal name changing.
3.Restart the PC.
4.Now enable the DHCP on bothside.
Dec 22, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I changed the name of my wireless router and can't connect now
delite your previous saved network and network settings
Feb 03, 2009 | Linksys Wireless-G WRT54G Router
Wireless-g
Hello, You can reset the router to default. On the back of router push in the reset button/hole for 10-15 seconds. The defaults will be: IP address 192.168.1.1 User name admin. You shouldn't need a password. From there you can change username, password, SSID and enable WEP or WPA security. Hope this helps.
Mar 25, 2008 | Linksys Wireless-G WRT54G Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
236 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
