Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
Raymarine A-65 unable to find satalites
My Raymarine A-65 was replaced by Raymarine factory. When I got the new unit it has been unable to find any satalites. I sent the unit back to Ray, they in turn returned it to me saying that it worked fine for them. I still can't get it to find any satalite signal. Power is good, connections are all new and clean, view is clear. tried two different RS 12 antennas, same results.
    Problem Solver:
  • 10 Answers
If you have a loose RS12 try moving it around the deck and see if it make a diffrence.There might be something knocking it out.
If it is doing a cold start it cold take up to 10 min to get a fix. Once it has a fix it will aquire the next time much quicker.RS12's are mostly rock solid and get great fixes.
Also set the time up on the A65 to what you are at ,IE, universal time minus 5 if you are on the east coast of the US.Time set up is under the units menu. Hope this helps
Posted on Jun 15, 2009
I have a Raymarine C80 shart plotter / sounder with a DSM 300. I can't get the "status" light to come on and therefore I can't do a DSM reset. The fuse on the power input to the DSM was blown so I changed...
I would think it's prity much certain that the DSM 300 is duff. I returned mine back to Raymarine for test and repair £200 + VAT They came back unable to repair as they have no parts for the DSM 300 . They undertake to be able to repair units for up to 10 years and I think that's why they offered me a DSM 30 that will work with my analog display in my case a C70 MFDU and the existing transducer. OR an upgrade to a CP370 digital sonar unit, this will work on your existing tranducer but you will have to upgrade your display to a digital unit, I went for the upgrade and purchased an "a"series 9" MFDU with a chart, fantastic performance. This has left me with a spare analog MFDU that will hopefully keep my radar running a little longer before I have to go down that road and upgrade.
Hope this helps
PS there was no extra to pay so a CP370 for £240 was a good deal
Oct 17, 2017 | Raymarine C120 System Pack C120 Raystar...
Sony KDS 55A2000 Unit has no Blue hue... only green and red. checked the inputs and sat box (sub'd) all the inputs are correct. can not adjust the hue to recover green. bulb is fairly new. ...
Unplug,replug tv and satalite box both an hour later.The tv,will reset itself,back to factory.Satalite box should upgrade it softwares.Tv now should have all it colors back.Not,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Sep 14, 2010 | Sony KDS55A2000 55" HDTV
My GPS Raymarine (installed in 2001) with Raytheon Raystar 120 antenna indicate offen a NO FIX. A technician tells me that there must be a problem with the antenna and that the best solution is to...
Before you buy a new one if that is a raytheon raystar unit there is a lithium battery inside the unit check that first thats all you may have to replace.
Sep 04, 2010 | Raymarine Raystar 120 GPS Receiver
Trying to connect a furuno fcv-585 to a raymarine a-65 via nmea with difficulty !!
Just remember this tip Nmea out + goes to NMEA in + and so on. After that you have to make sure the unit is set up to send those sentences and or receive them. Aside from that it should be pretty easy. However if you hook them up wrong you may blow the port (you won't know that you did it either) No smoke no nothing it just wont pass or receive data.
Nov 27, 2009 | Raymarine NMEA 0183 (E55059)
A-65 screen has fine scratches/clouds
My Raymarine A65 was so bad in daylight I could not read the screen. Used Never Dull polish from ACE hardware, similar to Brasso, and it took every scratch and cloudy mark off the screen. The can documentation includes glass as one of the items it?s safe to use on. Looks new again, Good Luck, Paul
Apr 08, 2009 | Raymarine A65 Combo GPS...
DSM Port on RayMarine C80
The only other way would be to change the PSU board in the unit. The connector back plane is connected to this board.I am a authorized Raymarine repairer. I could drop ship you the board from Raymarine and email you an instruction manual on how to change it.I am not located in the US so shipping the unit to me for repair becomes expensive.You can also check with your dealer in Seattle first but I do not think that he can buy the board from Raymarine. Raymarine policy on repairing product is different from country to country. We are on the other side of the world so Raymarine allows us to repair there product as it is to costly to ship it all back to there repair facility in the states or the UK.If your unit is still under factory warranty then if you open it it will void the warranty.So then you would have to send it to Raymarine. With a diagram if you are natural a technical person you will not have a problem changing the board.If you are technically challenged I would say send it to Raymarine. Hope this helps.
Aug 28, 2008 | Raymarine C80 GPS Receiver
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
Ray Marine c120
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Jan 31, 2008 | Raymarine E120 GPS Receiver
RayMarine sl520 constant re-boot
Double-check that the unit is getting adequate power to it (at least 10.6 V DC.
Otherwise, Raymarine is probably going to need to look at this one as the CPU in it may be defective.
Dec 04, 2007 | Raymarine SL520 GPS Receiver
Raymarine GPS system HALT ! URGENT PROBLEM
To get back up and running you are going to have to reset the unit. This is from the handbook:
Note: Take care - factory reset clears allWaypoint and Route databases.
➤ To perform a factory reset:
1. Power off the unit.
2. Press and hold CLEARwhilst powering up until <Erase backup procedure>
is displayed.
3. Either press CLEAR to abort Factory Reset and resume normal
Power-Up or press ENTER to continue Factory Reset.
4. Press ENTER again; the unit restarts as for a first time PowerUpwith
all values reset to their original factory settings
When you hit port and have an internet connection, make sure you are running the latest software version, currently listed online as version 1.09. You can download it here:
http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=965
Sep 10, 2007 | Raymarine Raychart 435 GPS Receiver
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
142 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
