Vacuums Logo
Posted on Sep 16, 2010
Needs parts for a FranklinChef FBM2000 Bakers Oven
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Sep 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
9911
Points
50
Look on Craigs list
Modie is number S3325H Euo-Prox Select Steamer I broked the end off I can't fine my book try to clear my oven
The Owner's Manual for the EuroPro S3325H Canister Steam Cleaner can be found online here:
http://www.sharkclean.com/manual/S3325H_REV_1103A.pdf
The manufacturer does offer Parts & Accessories online for a number of models; however the S3325H is not listed at this time. If you need parts, you might conisder registering your machine with the manufacturer via the website and then contacting them either using their Live Chat feature or try their Toll Free number: 800-798-7398, to inquire about parts for your model.
If I have misunderstood your question, please feel free to send a followup message.
Thank you for using FixYa!
My toaster oven elements heat up pretty quickly and then go out for a few minutes and them come back on and keep doing that....toast doesn't get done because of it and tonight I tried to cook some hot...
You trouble is intermittent operation. Fix it by checking the thermostat and power button switch also the cord. Check it use a analog tester set to Rx1. All of that is test through continuity, so if there no fluctuation in the meter reading, there is defective parts. An intermittent part(s) operate sometimes good and sometimes bad. Check those parts carefully.
Good luck.
Jul 17, 2011 • Vacuums
1helpful
Replace a melted Duralit toaster cord that melted from it touching my toaster oven. Need to replace the whole cord. Thanks, Shelley
cut the bad part off the ac cord then use "****" conector to crimp on a new cord. make sure and note the stripe on the cord and that indicates the neutral wire. the stripe is on the outside of the cord on one of the sides. the stripe is molded on to the outside of the wire on one side only
Apr 18, 2011 • Vacuums
I have the porcelain coated pans and the kids burnt chilled cheese and just can't seem to get it clean now
You can use spray-on oven cleaner, such as "Easy Off" or any similar store brand. Do not use oven cleaner on Aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubber handles. Wear rubber gloves when working with oven cleaner. It is a very powerful cleaner and can burn your skin.
  1. Put the pan in your empty kitchen sink.
  2. Spray it on generously with oven cleaner.
  3. Leave it overnight, 8 hours or so.
  4. In the morning thoroughly rinse and wipe all the areas you sprayed, including the sink.
You should have a clean pan and a clean sink. Refer to the oven cleaner's label for further instructions and safety hazards. Choose the type of oven cleaner that suits your needs. In my experience, "Fume Free" oven cleaners take longer and don't work as well. Seemingly, the more noxiously fumed cleaners, ie ones containing Lye (Sodium Hydroxide), work better and faster.
This works for porcelain coated pots/pans, stainless steel, steel, glass, etc. Do not use oven cleaner on aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubberized handles.
Apr 02, 2011 • Vacuums
Can i get a replacement plate for my microwave oven model number MW8625W? dO THEY STILL MAKE THEM?
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Mar 26, 2011 • Vacuums
I have a Betty Crocker BC 1679C Toaster Oven and I need a replacement control knob (the dial that you turn to adjust the temperature). Can you please advide where I can find this part.
I couldn't come up with the part# or even who manufacturers Betty Crocker's appliances. I do notice on their website (bettycrockerstore.com) that they have an email contact for help with replacement parts. It is on the contact page. Under 'select a subject', choose 'product information'. "Help with replacement parts" is the second option. There is also an 800 number and a mailing address listed. Here is the site: http://www.bettycrockerstore.com/HelpContactUs.aspx
Hope this helps
Jan 30, 2011 • Vacuums
My hamilton beach convection / rotissier over model 31197 oven button has a shortage in it, how can i fix it the button that turns the oven off and on, if you turn it on the oven doesn't come on but if...
Sounds like a contact problem in the switch-
Question: How old is the oven?
Is it possible that the switch is worn out?
If so-- and lets just say the switch cost $25, plus postage,
would you want to invest that money, and time, and be without the oven while you wait for parts,
or would you rather invest that money in a new one?
If you want to repair it, we need to dig into the insides, and do some trouble shooting--
Do you have the tools, and the interest to dig into it?
Please answer the above questions-- get back with me,
and we'll go to the next step that you prefer.
Mack B
Jan 15, 2011 • Vacuums
Need replacement part for PIZZA baker mod: PS75891, it is a thermo switch No.E211649. this is counter top pizza oven
I don't see any parts available for this, most parts are propriotory and can't be purchased seperatly. I checked online and this is selling for around $60.00 new and it seems that this oven has been discontinued. If you know what part it is you might be able to match it up at a local electrical supply or appliance repair. I have no idea what a new switch would cost but at $60.00 replacement of the oven might be a better choice.
Dec 23, 2010 • Vacuums
I have a white B&D toaster oven. Something burned in the oven and the smoke came out the door and scorched the white part above the door. What's a good way to get rid of the stain.
you need to sand that stain down with sandpaper and then re-paint the area with a high temperature paint......hardware stores should sell it....it's trade name is called...."mr. touch up"......it is speciffically made for microwave ovens but is also very good for your oven.....the paint must be high temperature type since your oven is high temperature.....good luck
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
