Question about Sylvania G-Netbook
My sylvania notebook keeps displaying baud rate setting error which is enabling me to connect.
If you are getting the error code concerning the baud rate.. You need to go into my computer, click on control panel, go into network and connections and delete my connection. This will take care of the error message then you can continue to connect your device to wifi.
Hope this helps
Posted on Mar 30, 2011
Getce6B1 screen comes up when I try to connect to a wireless server and then asks to change the baud rate setting
but without doing all of these steps is not possible?
I have only collergarmi with the wi-fi.
I do not have to configure the modem.
Mar 08, 2012 | Sylvania G-Netbook
Change baud rate on okifax 5050
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Buddymc
Feb 27, 2012 | OKI Office Equipment & Supplies
What is the normal setting for the baud rate for the 7"Sylvania netbook?
YOu didnt post what model your netbook is, but i'll answer the best i can. Netbooks typically do not come with a modem, so you will most likely only be able to connect via WiFi or an Ethernet connection. If the netbook does by chance have a modem, it will be 56K.
Feb 09, 2011 | Sony Computers & Internet
When I try to connect to internet I get this message you have been diconnecter from the remote computer you dialed verify the baud rate setting and retry the connection. my baud rate on desktop is...
How are you trying to connect to the Internet? It sounds like you are using another computer as a gateway, so if the other computer is offline you will not be able to connect. If you have another way to connect (such as a satellite, DSL, or something else like them, you need to disable your current connection. Go to control panel, internet options, connections, and see how you connect. IF YOU DO CONNECT THROUGH ANOTHER COMPUTER DO NOT CHANGE YOUR CONNECTION. Otherwise, disable or delete that connection, and then go to the lan portion (towards the bottom of that menu) and click it. In the new menu, unclick automatically detect settings. If you are not sure what you are doing, write back and be more specific with your question.
Sep 22, 2010 | Sylvania G-Netbook
Trying to get my sylvania 7 inch netbook to bring up the internet, but it keeps saying to verify the baud rate settings
I used a router and adjusted the same conf. for both the router and the net book. All you need to do is to match both. I also know that you need to activate the wi fi by pressing the fn f9 buttons at the sometime. Try to log on and if it says connected but you are not able to use the net go to internet options and type yahoo.com or goggle.com. If you still not able to connect shut down and log on again. It works. Hope this helps Mrs.Mo
Sep 08, 2010 | Sylvania G-Netbook
I have cisco 1841 router stuck at Rommon> only IOS is ok,but still in this mode/.
what shows the following?
dir flash: If IOS is ok the follow the below step The router will guide you through changing the registry. You want to press y to chang the configuration. The only other change you need to make is the change to the console baud rate, set that to 7 (115200).
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
disable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]: y
enter rate: 0 = 9600, 1 = 4800, 2 = 1200, 3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200 [0]: 7
change the boot characteristics? y/n [n]:
Configuration Summary
enabled are:
console baud: 115200
boot: the ROM Monitor
You must reset or power cycle for new config to take effect.
rommon 2>
3. When you reset the router in your console window you will see characters that you cannot read. You have to stop the session and set your baud rate to 115200. This will let you increase the speed that you use to transfer the file.
4. At the rommon prompt enter xmodem -c {filename}
5. When prompted, enter y to continue
6. From your hyperterminal prompt, click on transfter then send file
7. Select the IOS image then change the protocol to xmodem via the dropdown box then click send.
8. After the IOS has been downloaded, change the boot order by using the confreg 0x2102 command.
Dec 18, 2009 | Cisco (1841) Router (cisco1841)
Change baud rate on panafax uf880,885
That won't make any difference. ALL fax machines are ANALOG and won't work on a DIGITAL phone lines reliably
Nov 17, 2009 | Office Equipment & Supplies
I need to set my baud rate of my HP3390 low so it will receive faxes via magicJack I cannot find the baud rate in the menu of the HP3390
Please follow the steps given below to reduce the baud rate on your printer.
1. Turn on the HP.
2. From the keypad, press * and # keys simultaneously.
3. Press 1, press 2, and then press 3. Service followed by a number will be displayed on the front panel.
4. Press the right-arrow to select System Configuration.
5. Press Enter on the front panel.
6. Press the right-arrow to select R/W Parameter.
7. Press Enter. Parameter 0 will be displayed on the front panel.
8. Press 1, press 5,press 1 (i.e,151) and then press Enter. The display should read Value followed by a number (example, Value 60).
9. Press 2, press 6, and then press Enter. This will display Parameter 0 on the display.
10. Press 1, press 5,press 3 (i.e,153) and then press Enter. The display should read Value followed by a number (example, Value 60).
11. Press 0, and then press Enter. This will display
12. Press Cancel repeatedly, until the display reads the date and time.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 01, 2009 | Office Equipment & Supplies
HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Mar 04, 2008 | HP Officejet 9110 All-In-One InkJet...
Programming my bc246t
Hello Ranger66,
I had the same problem. did you set the radio to "xfer information"? if not, to do this follow these steps
1. press menu display ---menu--- and program system under
2. twist thr top right knob until "xfer information is displayed".
3. press the "E" or yes button, this will disply the baud rate.
check to see if the radio connects.
Dec 31, 2007 | Uniden BC246T Handheld Scanner
Sylvania G-Netbook Logo
1,116 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
