Question about Stanley Bostitch Nail Gun
I haved a stanley N 12 and it does not leak but at 100 psi it sometimes does not drive the nail all the way, does it need more presure or is it something else?
    President:
  • Stanley Master
  • 1,383 Answers
Remove head and check oring to piston. The piston/oring should fit snug in cylinder and not drop down under its own weight. Also check that the driver shaft thread is not stripped at piston. Lube with silicone paste lube(availabel at lowes in the plumbing department,used to lube fauced orings ). Parts for N12 are getting scarce. Usually the cylinder seal and the upper bumper will be first to give out. The vinyl that they used caused these parts to self destruct. Good luck
Posted on Sep 18, 2010
Nail doesent come out all the way,half in board half still in gun,happens about every 5th nail
air presure droping on you try on a bigger compresser and oil up air intake should help
Jul 13, 2011 | Stanley Bostitch N66c1 114"to 212" Coil...
When I go to shoot the nail, it won't sink the nail all the way. The head of the nail is still an inch or so out of the lumber. Also, when I push the safety against the nail, sometimes it won't shoot. I...
Remove the nails and dry fire the gun against thick rubber or coiled hose to absorb impact. Driver should be visable about 1/4 inch past the nose. If not visable then tip of driver may have been broken off. If driver length ok then time to reseal gun to regain full power. To solve irregular firing, replace the trigger valve (usually part# TVA6 ) and examing the trigger itself for worn contact surface or worn retainer roll pin. Parts are available at www.toolpartsdirect.com. Good holidays
Dec 28, 2010 | Stanley Bostitch F28WWMCN 28° Industrial...
Adjusting airpresure
There is nothing on a nailer to adjust the air pressure. You have to do it at the pressure regulator. It is feasable to mount a regulator at the gun but more likely it's on the compressor. Most nail guns are rated for 90 to 120 psi. Set your regulator to hold the hose pressure between 90 and 100 psi. Using higher pressure to set the nail will ruin your nailer. Use the depth adjustment on the gun to set how far the nail is driven.
Sep 23, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Bostitch Nail Gun wont release and shoot nail
I had purchased a bostitch bt200 and am just now trying to use and after loading the nails 18ga 2" brads made by bostitch connecting to a small compresor that had 20 psi I pushed the nailer flush with the board and pulled the trigger and had no nails ejected. Is there something else I needed to do, manual was read.
Sep 04, 2010 | Stanley Air Tools & Compressors
LOW TIER PRESURE
if its 1 tire low obviously look for a nail in the tread or a leaky valve stem. if you cannot find a nail/screws etc in the tread. take stem cap off spray windex on stem right into the center, if you see bubbles, your stem is leaking, replace the core, cheap... available at auto stores, also need special tool to remove stem( cheap).
if all 4 are low, might be due to cold temps, tires loose i think 3 psi per 10 deg drop in temp,
Mar 10, 2010 | 2003 Chevrolet Impala
My 1996 ford f150 with the in-line 6 cylinder was just rebuilt from the head up and all new injecters were installed. sometimes after driving for a while and after turning the engine off the vehicle will...
get a fuel presure gadge and check the presure after setting hook up the gadge starty it up let it set see if the presure drops to 0 if so and you have no fuel leaks and you know that none of the injectors are leaking then it might be the fuel pressure regolator or the fuel pump the psi should be around 35 40 psi i think
Dec 29, 2009 | 1996 Ford F150 Regular Cab
Have a stanley bostitch framing nailer. Nails
Normally, yes- depends on how old the nailer is. But first, let's ask: are you getting at least 90 psi of pressure to the rig?
If so, you may adjust the nailer with an allen wrench, or with a thumbwheel, both of which are located near the firing mechanism.
IMPORTANT: before you mess with it, be sure no pressure is left in the unit, otherwise you may be on here asking how to extract a framing nail from your skull while your hand is attached!
Nov 25, 2009 | Stanley Air Tools & Compressors
Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
May 31, 2009 | Stanley Bostitch Coil Framing Nailer
Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
May 23, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Stanley Bostitch Nail Gun Logo
77 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
