Question about APC (BK500TW) UPS System
Intermittent "On Battery warning"
I don't know what's up! I have my cable modem, CPU and Monitor hooked up and it recently began to cycle to On Battery for the standard four-beep warning at random times. Other times, sometimes during the same cycle, it doesn't make it to four beeps and then everything is fine for awhile! None of the other appliances hooked up to the same outlets show any change when this happens. Florida is notorious for "dirty" power conditions and I can usually see the results of dropouts and spikes in the lamps when they occur, but this doesn't seem to follow that pattern. The battery is 3 yrs. old, but seems to be doing well and it really hasn't been stressed more than a couple of times.
  • HarpMan1224 May 27, 2008
    KLPC,
    I found I had a driver problem that wrecked not only the keyboard function, but made some other undesirable things pop up. Like hanging characters in the stack, which made the cable modem hiccup and spontaneously reboot me! I installed a keyboard driver and it made it all go cuckoo! Since I uninstalled the keyboard, then reinstalled the generic driver Windows installs, my keyboard is still a little funny but it's better and no more probs with the APC or the modem! At any rate, look at any new drivers you've installed lately. Hope that helps!
  • Jocelyn Viau
    Jocelyn Viau May 11, 2010
    Have your installed the PowerChute 2.x software that came with the unit on your computer?
What was the problem and how did you solve it? I think I also have this problem. thanks in advance
Posted on May 27, 2008
No, I used to until I had to do a Recovery and I didn't reinstall it! But I found out the prob and have resolved it. Thanks for your time and assistance.
Posted on May 21, 2008
The router doesn't recognize the dsl modem. I have hooked up to the internet directly from the computer and modem-no problem using the same cable the router can't connect to the...
connect the Ethernet Cable to lan Port and make new connection from Window (PC also should connect to the Lan Port) and configure the username and Password (test it ) if it is going this mean the Wan Port Has some Problems......
Jul 12, 2011 | Computers & Internet
I just took all the cables off in order to move the monitor and CPU. WHen I hooked everything up again the monitor did not come on as it has in the past. I tried pressing the On button which I assume is...
Recheck your cables, particularly the VGA cable, it may not be seated well. Also, make sure the AC cord is fully seated at both ends since all modern monitors will put a warning on the screen even with no video (or sync) input to notify you that the monitor is ready but has no input. If nothing works, you may be the victim of a switching power supply in the monitor that will not start up any more.
Jun 21, 2011 | LG Televison & Video
How to hook up a PS3 wired. internet is cable but how fast i dont know.
you need an DSL cable modem. chance are if you have cox's cable inter net then you can just take the cable that looks like a phone plug form your computer and plug it into you ps3 the unplug the modem the plug it back in and the you are good. but you can not get on line with your cpu until oyu hoke the modem back up
Oct 04, 2009 | Video Game Consoles & Games
My monitor speakers are not working name of my monitor is Spectrum 9 GIrsA or GlrsA could you help me locate the problem . I know tht the speakers work ,because when I hook up another cpu the speakers...
check if you have installed your sound drivers and the monitor drivers , if they working good on other cpu that should fix your problem. if you don´t know how to check or update drivers let me know. and good luck
Jun 12, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Battery draining down when parked but no lights on
the central timer module is located in the back of the main central fuse box. This module contains the time contol elements for the heated rear window, interior lights and intermittent wiper operation, the module also activates a warning buzzer when the lights are left on
May 12, 2009 | 2000 Ford Focus
Monitor says
Try and kill the bios. Find the jumper next to the battery on the motherboard and move it from position 1-2 to 2-3 ... press the power button a few times. then put the jumper back to normal and give it a shot.
I would disconnect the cables first before anything and attempt to boot the system.. if it boots, then start plugging hte cables one after another until you find out what's causing the machine not starting correctly.
Good luck.
Jun 15, 2008 | Computers & Internet
System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
Intermittent ring and now fading display
You may have the problem fixed by now; but I had the same thing happen to me with the same phone and also hooking up to a voip type phone connection. The person installing it hooked it from the modem straight to the phone. He didn’t know why and when he left I still had the problem. The problem being the phone would not ring. After thinking about it I decided to hook the modem phone line to my house phone wiring and then hook the phone to the phone house wiring. It worked and I am not sure why but I think that the house phone wiring is grounded and that makes more voltage for the ringer
Aug 30, 2007 | GE 21028GE3 Cordless Phone
Medion Motherboard
if you cannot reach the BIOS settings screen at power-up, then try another known-good keyboard...it is likely dead.
Jul 05, 2007 | Medion (MT8381) (40004683) Motherboard
APC (BK500TW) UPS System Logo
182 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
