Question about ViewSonic N1930W 19 in. LCD TV
Tv goes black after start up - ViewSonic N1930W 19 in. LCD TV
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Oct 21, 2009 | Sanyo Televison & Video
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
Video goes black on startup
sems like your pisture tube for the tv is going slowly out. replace the tube or replace the tv, its cheaper to replace the tv then a new tv screen colour tube.
Aug 23, 2008 | Sharp Aquos LC-32D40U Television
Tv freezes, goes black, starts again
I had a similar problem, mine was a bad earth connection on the main (tv input) board. it earths through the screw mountings so check they are screwed in nice and tight, probably best to remove and then refit it.
Dec 11, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
ViewSonic N1930W 19 in. LCD TV Logo
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
