Question about Samsung HLP4674W 46" Rear Projection HDTV
I HAVE A SAMSUNG SP46L6HV REAR PROJECTION HD DLP TV AND IT HAD MAKING A NOISE BUT NOT THAT LOUD AND THEN ONE DAY IT WAS ON AS NOMAL AND JUST WENT OFF , MY HUBBY TOOK THE BACK OFF AND SAID THE LAMP WAS FLICKERING IM WORRIED IS IT JUST THE LAMP OR IS SOMETHING ELSE AS WELL AS THE LAMP AS I WONT BOTHER TO BUY A LAMP IF THERE MIGHT BE OTHER PROBLEMS ALL HELP GREATLY APPRECATEIED THANKS
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Before it went out, was the sound like a fan or high pitched in nature?
Lamp can be removed (is is customer replaceable) to see if shattered inside.
I suspect a bad color wheel, which is not hard to replace. See attached photo of color wheel.
Examine lamp and if not shattered do not buy one to try.
I am here to help you for free.
Comment here and I will assist you.
SD TECH
Posted on Sep 16, 2010
  • SD Tech
    SD Tech Sep 16, 2010
    see color wheel
  • 4 Answers
Before you purchase a lamp. Turn on the TV and feel the top. If the tv is vibrating your color wheel ***'y came apart. last time I repaired one of these the cost of the lamp and color wheel made it not worth repair.
If you had low lamp warning - either on screen or with front LED indicator before lamp acted up, lamp replacement will be the fix. 99% sure.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Samsung sp46l6hv. lamp keep switchin off. the picture goes black still with volume on the goes off . tv goes back to stanby starts up then lamp goes off again this repeats . pls help
One of the most reasons that the samsung DLP tv will stop working is that the emergency switch on the back gets caught in the wrong position and makes your tv to turn off. Try to check the switch it is located under the lamp cover door. Good day and best regards.
Aug 19, 2011 | Samsung HLP4674W 46" Rear Projection HDTV
My Samsung DLP HD 46" TV just went Black &
Defective Color Wheel- Encompass parts Distribution 1-800-638-3328
Mar 06, 2011 | Samsung HLP4674W 46" Rear Projection HDTV
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
Samsung DLP making noise and is picture out
Lamp probably went out. Refer to your manual regarding lamp replacement.
May 16, 2010 | Samsung DLP HL-P5663W 56" TV
No sound, just clicking noise
Is your TV a SAMSUNG DLP TV Model HLN437W Rear Projection Digital HD?
If so I found a TROUBLESHOOTING GUIDE @
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010300&model_name=HLN437W
A probably INTERACTIVE ONLINE SERVICE REQUEST FORM @
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
PHONE #S FOR SAMSUNG:
mobile phones: 1-888-987-HELP(4357)
  • Mon - Fri : 7am - 9pm (CST)
  • Sat : 9am - 6pm (CST)
digital HDTVs: 1-800-SAMSUNG (1-800-726-7864)
  • Mon - Sun : 9am - Midnight (EST)
printers: 1-800-SAMSUNG(726-7864)
  • Mon - Sun : 24hrs
IT Products for Business: 1-866-SAM4BIZ(726-4249)
  • Mon - Fri : 9am - 9pm (EST)
All other products: 1-800-samsung (1-800-726-7864)
  • Mon - Sun : 9am - 9pm (EST)
To see PHOTOS of REPLACING a SAMSUNG DLP TV ballast go to:
http://forum.doityourself.com/electrical-c-d-c/248376-testing-ballast.html
Hope this is helpful.
Good Luck!
Jack iaria
Nov 25, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
No picture and no sound
you need a coler weal if it macks noise.
Oct 01, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLP4674W 46" Rear Projection HDTV Logo
429 people viewed this question
Henry  Thomas
Henry Thomas
