Question about Frigidaire FGQ332ES Gas Dryer
Replaced the ignitor and the gas valve coils but still no heat. Vac the lint everywhere and the unit turns and the ignitor comes on, but still no heat !
  • 23 Answers
Could be a safety thermostat here is a link for those items:
http://www.repairclinic.com/Appliance-Parts?s=t-FGQ332ES-%3d%3dc44
Sorry I did not have the parts myself to give you a deal, Keep me in mind for the future:
http://stores.ebay.com/Discount-Appliance-Parts
Posted on Sep 16, 2010
A whirlpool gas dryer will not heat up
If your dryer is not getting any heat, you need to make sure there is nothing blocking the vent. IE: LINT. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
• Heating element (For Electric Models)
• Burner operation (For Gas Models)
• Ignitor (For Gas Models)
• Thermal fuse
I WOULD START WITH:
To protect from over-heating, many dryers use what's commonly called a thermal fuse. If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It's about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
Visually inspect your heating element for any broken or burned areas.Check the coil for continuity with a Volt Ohm Meter. If there's no continuity, it means that the element is bad and you need to replace it.
If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
Sep 28, 2013 | Home
My dryer will not dry effectively, it is very slow to dry even on the high heat settings, any ideas?
i looked up your model number and you have a gas dryer not electric,if the vent line is clear and the metal duct that the lint filter slides into is clean i would say you have bad gas coils located on top of the gas valve,when the coils go bad they will work correctly for the first 15 to 30 minutes,when they heat up they fail and the flame won't ignite,so do this remove the screws that hold the bottom panel on,remove the panel and vac out any lint you see,if you have a shop vac you can set the vac up to blow and blow off the motor and blow all the lint forwards and vac it up,do this with the dryer unplugged,remove the lint filter and take out the screws that hold the metal duct in place and clean the duct out,put it back together except for the screws that hold the bottom panel in place but just stick the panel in place,put some clothes in and start the dryer,after around 20 or 30 minutes remove the bottom panel so you can see the ignitor,if the ignitor glows orange but the flame doesn't ignite and the ignitor goes out then you have bad gas coils.you should take the bottom panel off and remove the lint filter duct and blow and vac it out once a year,also if you vent line is long remove it from the back of the dryer and blow it out with a leaf blower,make sure nothing is blocking the outside vent like a cage or a piece of screen so the lint can blow out and not get blocked.the part number for the coils is 279834 and they are around 25 dollars,unplug the dryer,remove the bottom panel,remove the two phillips head screws,remove the cover,slide the coil up and off of the post,unplug the wire and connect it to the new coil,watch out on the big coil,there's a spacer that has to stay on the post,sometimes it gets stuck in the old coil when you remove it,let me know how you make out.
Mar 19, 2013 | Kenmore Elite HE4 Electric Dryer
Maytag gas dryer m# ldg9800aal. Heat element comes on each time I start the dryer BUT turns off after a few seconds each time. I hear a soft "click" each time it turns off. Heatl does not come...
Check your high limit on the heater housing. It could also be the light sensor on the side of the heater housing if it dont see light it will turn off the gas . Looks like a little glass window.
Sep 18, 2011 | Maytag Dryers
LG DLG2526W gas dryer not heating after 1.5 years. Unplugged unit to attempt reset. Cleaned out back vent which did have some lint build-up. Still not heating. Is there a reset button somewhere or do I...
I was having similar symptoms and have finally solved my issue.
We noticed that clothes weren't drying as well as they use to...when using sensor dry they would come out slightly damp (just barely). Intermittently we would smell natural gas in the laundry room. After reading numerous forum posts, I decided to swap out the main control board because many people said changing the ignitor and gas valve didn't fix the problem. I thought that I had fixed the problem as we didn't smell gas for a few weeks.
Well, the problem did come back a few weeks later. I ordered a gas valve thinking that was the most likely culprit. The swap out that part I had to remove the drum which exposed everything in the dryer nicely. It turns out the exhaust tube had dislodged internally and a decent amount of lint was being blown inside the machine. Lint was everywhere.
The lint had built up inside the gas tube and must have caused turbulence in the gas flow which prevented it from lighting properly. I cleaned everything up, reconnected the exhaust tubing and taped it securely before putting everything back together. I didn't replace the gas valve as the original one ohmed out properly. The dryer has been working like new for several weeks now.
I hope this helps other with similar problems.
Apr 02, 2010 | LG Dryers
I have a Maytag MGD5800TW Gas Dryer. It does not heat up. What should I check?
First, Remove small plastic tab on front panel of dryer lower left corner. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Leave the dryer cycling while observing. When the dryer heats to temperature the flame will shut off. If the gas valve coils are bad the next thing to happen will be that the ignitor will glow orange again, the valve will click again but the flame won't light.
If the gas valve coils prove bad, based on the observations above, follow the procedure below to replace the coils. If NOT, come back with the results of your observations.
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Remove lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Sep 20, 2009 | Maytag Dryers
UNIT IS KENMORE M#417.94072300 UNIT WILL START
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 5303931775.
The disassembly procedure is covered beginning on page 57 of the manual listed at the link below. Operation and replacement of coils is covered at page 68. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble. Good Luck
Click on the link and print out the manual below or refer to it. It should give you all you need to know to disassemble and repair the gas valve coils.
Dryer Service Manual
Sep 14, 2009 | Kenmore 72622 Gas Dryer
Gas dryer has no heat
a small sensor or eye detects the glow plug or ignitor to make sure its on before the gas valve will open,because bad things happen when natural gas get everywhere,they get full of lint ,take off the back and clean around it try to start it while watching it ,the ignitor should spark or glow.it may have burnt out
Sep 14, 2009 | Kenmore 73952 Gas Dryer
Flame does not cycle on Gas Dryer
This problem is caused by faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves. It is recommended that if any of the gas valve coils are suspected of fault, that they both (all) be changed at once. Hope this helped and best wishes.
Sep 01, 2009 | Kenmore 63942 Dryer
Oven gas doesn't come ouy. Boiler works, ignitor
Ever though the ignitor glows it may still be bad. The gas valve circuit consists of the main oven control, the igniter and the valve coil. As a properly functioning ignitor heats up, it allows more current to flow through the circuit. It finally reaches the point where it opens the gas valve. A failing ignitor will not reach that point. The fact that it glows at all tells you the control contacts are closing and the gas valve coil is nt bad. ****If you try this repair, make sure to remove power from the unit. Be careful handling the ignitor as it is extremely fragile.
May 02, 2009 | Kitchen Ranges
Whirlpool gas dryer not heating up consistantly...
replace the sensor on side of the heat tube where valve and ign is located
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
82 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
