Question about Kenmore Refrigerators
How do i retrieve the program code before installingg a new control board on my mdoel # 596.77539600 refrigerator.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
The program code is printed on the model and serial tag in the upper RH corner of the fresh food section.
Posted on Sep 16, 2010
I am talking abt maytag refrigerator . New board panel and the PE0000 just keeps flashing
You need to program the new board. Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the
Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated.
The Programming mode can be exited at any time
Oct 13, 2016 | Maytag Refrigerators
How to check for a bad sensor on my MFI2569YEWO maytag fridge? We've replaced the control board in the back and display board in the door. the display reads PE0 000. Can't get it to program. HELP ME!
Patti when you change the main control board you have to reprogram the refrigerator to understand the board there is a code just below the model number and here are the instructions you need to follow them carefully
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word "Code."
2. Press and hold Freezer Temperature Down Keypad within 3 seconds .
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).
Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
http://www.appliance911seabreeze.com/
Aug 09, 2016 | Maytag Refrigerators
I just replaced the control board and now it won't reset
Hi try this. 1 press & hold the door alarm keypad. .2 press & hold freezer temperature down keyboard within 3 seconds. .3 release the door alarm alarm keypad and wait 3 seconds. 4.the control will DISPLAY PE to indicate the programming mode 5.entry is confirmed by pressing the freezer temperature down keypad once more. .6 the control will display the current program CODE this program should be validated with the program CODE printed on the unit serieal plate ..NOTE.IF THE PROGRAM code is correct the programming mode is excited by pressing door alarm keypad for 3 seconds. .7.press the refrigerator temperature up keypad or refrigerator down keypad to change the digit value with each key press. 8,. the decimal point indicates the selected digit press the freezer temperature Up keypad to select next digit. . 9.. Once the desired program code is entered press & hold the freezer temperature down keypad until the program CODE begins flashing indicating it has been saved.Note.if u attempt to enter an invalid code the control will not save the new code ...but will beep ,,(the unit will not run with a program code of 0000 ,). Once the program CODE has been saved the programming mode is excited by pressing any key.if the new code is incorrect this process should be repeated.the programming mode can be excited at any time by pressing door alarm key for 3 seconds or will exit if unattended for 4 minutes..good luck
Jun 16, 2016 | Maytag Refrigerators
How to program a w10319823 Kenmore refrigerator control board
Yes, here are the instructions to program:
Programming Mode:
1. Press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature DOWN /- Keypad within 3 seconds.
5. Entry is confirmed by pressing the Freezer Temperature DOWN /- Keypad once more.
6. The control will display the current Program CODE. This value should be validated with theProgram CODE printed on the unit serial plate.
7. Press the Refrigerator Temperature UP /+ Keypad or Refrigerator Temperature DOWN /- Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature UP /+ Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature DOWN /- Keypad until the Program CODE begins flashing
Feb 05, 2016 | Kenmore Refrigerators
Installed a new control board in a Whirlpool G15FSAXVY04, display reads PE0 000 flashing, what should I do next
You need to program the control board to match the refrigerator. Look for the serial plate and locate the number following "Code". That number is the program code and you will need that value.
1) press and hold Door Alarm keypad.
2) Press and hold the Freezer Temp Down keypad.
3) Release the Door Alarm keypad and wait 3 seconds. The refrigerator display should read PE - programming mode.
4) Press the Freezer Temp Down keypad to confirm that you are in the programming mode. Compare the Code number displayed to the one you recorded off the serial plate.
5) If they are the same, press and hold the Door Alarm keypad for 3 seconds to exit the programming mode.
6) Otherwise, press the Refrigerator Temp Up or Down keypads to change the first digit in the program code to get the correct value.
7) Press the Freezer Temp Up keypad to move to the next digit in the program code to adjust that. Use the Refrigerator Temp Up/Down buttons.
8) Repeat steps 6 and 7 until all of the digits match the Program Code from the serial plate of your appliance.
9) Press and hold the Freezer Temp Down button until the display begins to flash to save the code. If you hear a beep, the code is incorrect and was not saved.
If you heard a beep, return to steps 6 and 7 to correct the program code. Then go to step 9 again. If the code was saved, press any keypad to exit the programming mode.
I hope this helps.
Aug 08, 2015 | Whirlpool Washing Machines
How to progam main control board on Amana refridgerator
The code instructions are on the tech sheet that is taped to the underside of your refrigerator.
Remove the grill along the front bottom of the refrigerator and look around under the cabinet for the tech sheet. It's usually in a bag or envelope taped to the front right underside of the refrigerator. From there, you just need to follow the instructions.
Oct 22, 2014 | Refrigerators
ICE MAKER DISPLAY FLASHES. ICE MAKER DOOR OPEN AND CLOSES BY ITSELF NO WATER OR ICE WHEN PROBLEM OCCURS
is this a maytag refrigerator you need high voltage board located on back of refrigerator check with your local appliance parts distributor dont forget to follow instuctions with new part you got to program code of frefrigerator model plate into new control board
Jan 28, 2011 | Refrigerators
Personality code
osborne, you can try this procedure.
PROGRAMMING MODE: (FOR PROGRAMMING A NEW CONTROL)
NOTE:
1. Open the Fresh Food door and press and hold the Door Alarm Keypad.
DIAGNOSTIC TESTS
6. The control will display the current Program Code. This value should be validated with the
Program Code printed on the unit serial plate.
NOTE: If the Program Code is correct, the Programming Mode is exited by closing the Refrigerator
door(s).
9. Once the desired Program Code is entered, press and hold the Freezer Temperature Down
Keypad until the Program Code begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program Code the control will not save the new code,
but will beep. (The unit will NOT run with a Program Code of 0000).Once the Program Code
has been saved, the Programming Mode is exited by closing the Refrigerator door(s). If the new
code is incorrect this process should be repeated after closing the Refrigerator door(s).
The Programming mode can be exited at any time by closing the Refrigerator Door(s) or
i hope i was able to fix your problem.
Jul 02, 2008 | Maytag MFD2560HES Bottom Freezer French...
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag mbf2258hew replace jazz board
bug, the jazz board is pretty easy to replace. The light cover will slide off toward the back. Now if you look behind the control panel you will see two slots. Take a flat blade screw driver and push the cover tabs in while pulling down on the cover. The cover will come down. Two slats slide in on the front and will release, disconnect the harnesses and install the new board. Reverse the process. Catriver.
Sep 04, 2007 | Amana AFB2534DE Bottom Freezer French Door...
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
