Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper stuck - Canon PIXMA MP160 All-In-One InkJet Printer
  • 51 Answers
  • 1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  • 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  • 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  • 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  • 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  • 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  • 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  • 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
  • Posted on Sep 16, 2010
    My paper keep getting jam and will not go into print
    1. Turn off the printer.
    2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
    3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
    4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
    5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
    May 14, 2011 | Office Equipment & Supplies
    I have paper stuck in it and can not get it out
    Hi
    When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
    2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
    3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
    4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
    5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
    * To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
    Jul 18, 2010 | Dell 1110 Laser Printer
    It's jammed
    Mar 12, 2010 | Lexmark X4530 InkJet Printer
    Regular paper jams and printed images are not straight
    hi,
    follow these steps:-
    5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
    Thanks!
    mannu_rakesh
    Aug 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
    Paper jams
    hi,
    Thanks!
    Aug 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
    How do I clear a paper jam?
    hi,
    Thanks!
    Aug 02, 2009 | HP DeskJet 932c InkJet Printer
    Paper jams and the light comes on
    hi,
    5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
    Jul 13, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
    My Officejet pro has a paper jam and I can't release it. Thanks
    Jul 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
    How to remove a paper jam from the vivera paper tray
    Jul 13, 2009 | HP Photosmart C7280 Laser Printer
    Printer cartridge stalled
    # Turn off the printer.
    # Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
    # Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
    # Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
    # Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
    Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
    Canon PIXMA  MP160 All-In-One InkJet Printer Logo
    60 people viewed this question
    old marine
    old marine
