Question about Frigidaire GLGFZ386F Kitchen Range
The panel where you turn on the oven does not work. it wont come on at all so we cannot use the oven
  • Frigidaire Master
  • 17,130 Answers
Might be the switch is faulty or the control panel is faulty.
Might have to remove to see if this is a power related issue or failure inthe controller unit.
Nothing like looking into to check from the fuse, the power and the controller to get a first hand information.
Posted on Sep 16, 2010
  • 23 Answers
First reset the breaker to reset the stove. Sometimes that will work since the oven does seem to be newer. If not the clock control sounds like it is shot. It is a very easy a repair to do yourself. Here is a link for the breakdown of your unit, And the clock at about 50.00 off retail from anyone else:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-GLGFZ386FCJ/1428/0124002/R0904169/00001?blt=06&prst=&shdMod=
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
There was a power cut in the house and when the oven came back on the timer works apart from the 'end' time button, this is retaining the actual time. I've tried pressing the - button to get it back to...
A simple try you can do is to turn off the circuit breaker to the oven from your breaker panel. Wait about 3 minutes or so then turn it back on. This should hopefully "reboot" the oven panel.
I hope this helps! :)
Jan 13, 2011 | Electrolux EOD6330 Ultrafan Electric...
Wont get hot grill works think the element has
If it is a fan assisted oven, then it is probably the oven element that has failed.
This is usually located at the rear of the inner oven compartment behind a removeable panel
May 04, 2010 | Ovens
All stove top elements and oven wont work
Go to your home circuit/fuse panel and reset the fuse or circuit breaker for the range.
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
My GE Spectra gas oven worked fine last night. Today, the oven will not heat. The broiler and the burners work fine, as does the clean feature. But nothing when the oven is turned on.
Are you sure the cleaning process works, because usually when the oven wont work, the clean process wont work. If you are correct, then the problem is most likely the control panel not responding to the bake setting. This will require either a new touch panel or a new control circuit board.
Oct 11, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
GE mod.JDS27G0P2BG Oven Wont start
You have a bad electronic control board.
No repair.
It must be replaced.
Feb 21, 2009 | GE Profile JTP18 Electric Single Oven
ERD30S- oven wont turn on
Hi! jpdufilho
Try tuning off the power to the unit for 20 minutes. If this does not fix the problem you may need a new control board/panel. If you have a lot of lightning in your area you should have several surge protectors in your house. All electronic devices need some type of surge suppression.
InMrFixIt
Nov 09, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Frigidaire GLGFZ386F Kitchen Range Logo
123 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
