Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore 665.16705891 dishwasher
Opened the dishwasher today and found about 2 inches of water still in
the bottom. Any clue how to repair?
  • 868 Answers
First make sure it will run by hitting "cancel' or turning the timer to drain cycle.What is the Model& Serial number???I'll be happy to get this solved for you. :)
Posted on May 21, 2008
Kenmore dishwasher 665.16034401 no water pressure to top rack.
there is a blockage in the tube riser or tube arm..........
cheers
Jul 30, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
Did not drain last night
how much water? there should always be at least an inch to 1&1/2 inches in bottom to keep seal at top of motor wet if seal drys out thern washer will leak around motor.if alott more than what i wrote then check float valve if it is sticking then see if anything is under it l/e a fork or something that may be keeping the float from dropping down to the proper draln level
Dec 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher 665 water won't drain
Mine's doing the same thing, would love to know if you found a solution
Jun 19, 2009 | Kenmore Dishwashers
KENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Mar 12, 2009 | Kenmore Dishwashers
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Bosch slimline dishwasher flooded kitchen
Your debris filter needs to be cleaned. It is found under the dry bar in the bottom of the tub. It looks like a plastic mesh and you can usually remove it to wash it out if not use an old toothbrush etc... this should help.
Jan 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
151 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
