Question about Toshiba Satellite P25-S5262 Notebook
I need an A/C adapter for my P25-S5262 Satellite laptop. Online sellers keep sending me adapters with a plug that is too small for the power jack. The latest seller wants to know what the "psp number" is on the bottom of my laptop, and I can't say because all the numbers on all the stickers on the bottom of laptop have worn away: it's 6 years old! One seller I haven't tried yet has an adapter listed for my P25-S5262 model under this number: psp20u-1lkf3v. But then I look around and find other P25-S5262s with other psp numbers. Is there any way for me to find out what my laptop's psp number is, or can you direct to me someone who is still selling an original Toshiba A/C adapter for this computer, one with the big plug? By the way, I'm specifying "original Toshiba" parts because the previous two after-market adapters I've had both lost ground and induced electric shock. Since then, I've purchased and returned 3 wrong adapters. I am truly at my wits' end: please help.
  • Toshiba Master
  • 3,828 Answers
Ah its because at 6 years old the
Toshiba power source and power input plug you seek
has been discontinued and not superseded
A35 19v 6.3a 120w is a rare power source
one on ebay seller USA list this unit suitable for your
http://www.ebay.com/itm/NEW-Toshiba-Satellite-P25-P15-Laptop-AC-Power-Adapter-Charger-A35-19v-6-3a-120w-/401167479005
if not correct as in picture
you need to keep a look out online for sale any
used P25-S5262 with working power source
Posted on Mar 08, 2017
citycol
SOURCE: Toshiba Satellite 1800-911 DRIVERS
try this one: http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp?service=UK
Posted on Sep 29, 2007
flipbooks
  • 177 Answers
SOURCE: Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
Okay, lets troubleshoot this:
1)Does your laptop run on battery alone ?
yes )test your jacks continuity to the motherboard using a continuity tester or Digital Multimeter.
a)test between the center contact and the motherboard.
b)test between the outside metal cover of the jack ,and the motherboard.
c)If either of these fails continuity,replace the jack.
2)does your laptop now power up on AC ?
yes)Stop
No)Try the BIOS upgrade.
Posted on Feb 10, 2008
  • 2427 Answers
SOURCE: Toshiba satellite a105-s4004 power problem
It sint the power jack, but rather the Power control circuit. This circuit isnt repaired but replaced. I recommend taking this to an authorised service center or a certified technician of the latter is not easily avilable. If you choose to repair this at your own risk please remember doing so without the necessary knowledge will result in major damages.
Posted on Jul 11, 2008
  • 45 Answers
SOURCE: Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Posted on Aug 19, 2008
superbattery
  • 9 Answers
SOURCE: Toshiba Satellite M45-S359 Laptop Power Jack Issues
well the adapter for toshiba laptop is weak, and the most common method is to use a multimeter with the electroprobes connect to the anode and cathode.if it is normal, the pointer will fix in a short time.
Posted on Jan 10, 2009
Plugged in not charging
There could be several things wrong. You could have a broken DC jack on your motherboard. To prove this, wiggle the DC jack with the adapter plugged in. If the charging light comes on when you wiggle the jack, then your jack is broken. You could also have a defective AC adapter.
Jan 06, 2013 | Toshiba Satellite C655-S5125
WHAT DOES BLINKING BATTERY INDICATOR LIGHT MEAN ON A TOSHIBA SATELLITE LAPTOP P25-S5093
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Jun 17, 2012 | Toshiba Satellite (p25-s5093) PC Notebook
A105 won't power up...no power adapter light on
Did you experienced any overheating before that happened?
Apr 11, 2010 | Toshiba Satellite A105 Notebook
DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Nov 22, 2009 | Toshiba Satellite P25-S607 Notebook
My toshiba P25-S676/80 will not turn on. No
May be a bad power jack or the powercord/ac adapter may not be putting out enough power.Your powerboard may need to be replaced or even the button itself may not be getting contact to the board itself.
Jul 11, 2009 | Toshiba Satellite A60 Notebook
Will not power up, the charger checks fine. The connector on the motherboard seems good. Does the battery need to be installed to work on AC?
Yes it does have to be snugly inserted into its slot. If thats not the problem, then it might be ur hd.. stay away from seagate hds.
   `Nbryson
May 31, 2009 | Toshiba Satellite P25-S5262 Notebook
Toshiba p25... this unit will not power up. when the power plug is plugged in, the front power led will flash once and then nothing. the unit will not power up with or without the battery installed.
hello...if you have extra ATX power supply can you try to replace then try to boot the unit if not working u need to try and remove board inside the casing and try to test only,Mother Board,Memory,Video Card And Power Supply of curse..thanks...^_^
May 08, 2009 | Toshiba Satellite P25 Notebook
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some alcohol...you can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite P25-S5263 monitor problem
It could be a driver problem perhaps. Does the post screen show at all or is there absolutely nothing?
Dec 29, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite P25-S5262 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
