Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
I have a yardman 23hp 46 inch cut, it drives forwards and backwards ok but is very hard to push when switched off and in neutral, any ideas
SOURCE: need diagram or instructions on putting on new cutting belt
bex bissell proheat
Posted on May 21, 2009
lemmingleejn
  • 173 Answers
SOURCE: need to know what size and hoe to change belt for
If you are missing the manual, for the said model,
I have found that the simplest way, of figuring out the correct route for the belt, is to remove the deck, and hold the replacement belt above the mechanism, with the tension from the engine end.
Then 'mock up' the replacing proceedure, bearing in mind the correct direction the tensioner/s, move in.
Then it's not too difficult to figure it out the correct route.
Hope that's clear enough, good luck.
Posted on Jul 24, 2009
  • 95 Answers
SOURCE: our 20 hp 46" cut
Check to make sure the belt that runs from the engine pulley back to the transaxle is on all the pulleys.If it is a hydrostatic transaxle make sure the free wheel control lever at the back of the tractor is in correct position, or the brake plate may be stuck on but that would make a loud grinding sound.If it is a gear drive make sure the transaxle pulley is turning and make sure you didn't lose a rear wheel key from the axle,(if you had the tire off for a repair it is easy to lose the key when you go to put the tire back on.
Posted on Aug 09, 2009
  • 9 Answers
SOURCE: I have a MTD Yardman 46
Check the drive pulley rubbers for worn spots causing slippage
Posted on Oct 22, 2009
vincob
  • 718 Answers
SOURCE: What is the routing for
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Aug 14, 2010
Why mower will not move forwardo or backward I've replaced the idle pullt
There is a switch under you seat or attached to your seat somewhere that is probably not activating or is bad. This switch has to be fully depressed to activate the drive. It is a safety feature.
Aug 14, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Was cutting and stop moving forward and back wards belt in good condition
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
Apr 04, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Feb 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
How to change a Yardman M.T.d. transmission drive belt diagram on 46" cut?
You can go to the Yardman website and download the service/owner's manual.
Aug 18, 2014 | Garden
Mtd yardman differential
check your drive belts, pulley's and belt tensioner... you could of gotten better help if you would of included the model #
Dec 03, 2013 | Mtd Garden
My reverse went out of my truck and I put it in neutral to push it backwards and its like I'm in drive andcan drive forward what can I do to fix it
If reverse is done and you can only go forward is it shifting out of first. If its not then you need the transmission rebuilt. That's what happened on my truck.
Apr 03, 2013 | 1996 Dodge Ram
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
