Question about GE Refrigerators
Refrigerator is not cooling, not making ice. The ice has melted and dripped down into the pan. The refrigerator is 2 and 1/2 years old. The number is GSH22JFTWW - M931-PEX ICE LI/M931. SKU #559.306. It is a free standing side-by-side unit.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 16, 2010
Why is water coming out of refrigerator evaporator
During the cooling cycle, moisture in the compartment air freezes on the evap coils. During the defrost cycle, the ice melts and drips down. This is totally normal. There should however, be a drip pan and drain to control where the water goes.
Nov 16, 2014 | Whirlpool Refrigerators
Tip
Refrigerator not cooling-freezer section icing up
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
on Jul 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Water is leaking inside my lower compartment. Water comes from beneath the freezer...help me...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | Magic Chef Refrigerators
My whirlpool refrigerator is 4 year old. the ice maker is not installed I am getting water in my refrigerator now for over 5 months. There is no sign of water dripping down from the freezer or the back...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jan 21, 2011 | Refrigerators
Model # 61282100 purchased in 2002-on two occasions this year the freezer was dripping water down to fridge -advice was to unplug-wait for ice build-up to melt-why is ice build-up happening and how to...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 03, 2010 | Kenmore Refrigerators
HOT POINT FRIDGE - FREEZER DRIPS WATER
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Jul 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water is leaking inside the refrigerator. Refrigerator is 20 years old
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 18, 2010 | Amana ATB1832AR Top Freezer Refrigerator
FRIGIDAIRE frost free refrigerator seems to be leaking. Items in freezer are frozen...items in refrigerator are cold...any ideas? It has an ice maker which is working. Approx. 13 years old.
Oct 28, 2009 | Refrigerators
Water leaking into refrigerator
There are 2 types - the older types where you have a drip cup in your refrigerator extending to the back of your fridge into the wall and down the hose - OR the newer ones where the drain is in the freezer and goes straight down the drip pan. Look at the back of your refrigerator, if you see a tube extending down into a drip pan (on the compressor or next to it) that is your drain tube, if you can locate a drain cup in your refrigerator you can remove it and dislodge anything plugging your drain tube.
For newer or models without a drain cup, you'll have to remove the freezer panel and look at the bottom you should notice a hole, this is where the melted ice from defrost drips into through the tube and onto the drip pan below. Maybe there is excess freezeup ordebris or something blocking out the drain, so the water will spill over to the other opening where cool air passes onto your refrigerator - usually the culprit is excess ice buildup - if it is the case you can manually blow dry that section, clearing up the hole. once done you might also want to insert a piece of wire or long flexible cable to unplug the drain line.
Good luck.
Sep 15, 2009 | Kenmore 60721 Refrigerator
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
