Question about Nikon D90 Digital Camera with 18-105mm lens
Hi there, my D 90 was working fine then suddenly it was flashing ERR and CHA in the top screen.. al the photos I took are black and the previous pics are also black, none of the menu or other buttons will work... Any advice... Thank you Tara
  • jjbrown_1 Sep 19, 2010
    Hi there I did reformat the card and recharged the batter the memory card is not locked either.....THe camera is taking photos but I can not see them on the screen it is grey...I have downloaded the photos on the computer and they are all there.... Not to sure what is going on ..
  • jjbrown_1 Sep 20, 2010
    Thanx,
  • 4,924 Answers
Thi sis a card related error and it can be fixed by removing the batteries from it ..My advice is to remove the card also ..and insert it on a computer (card reader) and see if you can recover the picks and after that format the card ...This error happen on most cameras of this model and has the tendency to repeat..so be sure you always save the pictures periodically to avoid .loosing them ..
They seam to be sensitive about the memory cards..and lock themselves when something is wrong ..
Let me know if it worked..
Posted on Sep 16, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu Sep 16, 2010
    If you are using a Fuji card ..change it cause it seams to be particularly sensitive to that type of cards..
  • Catalin Turcu
    by the way ..when you get the card out ...take a look to see if it is not locked form the side slide ..(if it is a SD card ) ..
    To be honest ..removing and trying to format it ..(even if will take a few times to succeed ) wil fix the issue ..but will get back ...and randomly with no apparent cause..
    Sometimes may be just cause you used it in another camera ..or into computer ..or just cause is locked or for some reason do not make a proper contact and it not sees it proper..
  • Catalin Turcu
    Catalin Turcu Sep 20, 2010
    Tara,
    probably it is the ribbon from the display ...unplugged... in this case you have to open the cam...
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
CHA?
I found this answer on the Nikon web site.
3) Camera displays “CHA” in top LCD. The camera has detected an invalid partition type or is not working properly. Reformatting the memory card may allow it to be used. If an approved memory card causes the camera to display the "CHA" indicator contact the memory cards manufacturer for assistance.
Please note that the default disk format used in Windows XP is FAT32 and if a card is formatted with this setting on an XP system, a D1 series camera will report "CHA". Reformat the card as "FAT" to use in the D1 series camera.
Jul 11, 2009 | Nikon D70s Body Only Digital Camera
NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Mar 21, 2009 | Nikon D100 Digital Camera
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Error 99 or 90
err 99 is moisture or dew inside the camera.
Aug 14, 2008 | Bower SFD35C for Canon TTL Flash
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
Black Screen/Viewfinder
Mine too! Thank you so much for posting this issue!!
Apr 22, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Nikon D90 Digital Camera with 18-105mm lens Logo
35 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
