Question about Zanussi FJS1225W Front Load Washer
My top load washing machine smells like grease or oil when it spins what is wrong with it its only 2 years old.
SOURCE: oil and noise coming from my washing machine
I have had the exact same problem, when i pulled the whole thing apart i found the spindle which holds the drum in place, 2 of the three spokes had broken.
Posted on Mar 22, 2007
gdmisp
  • 66 Answers
SOURCE: washing machine
BELT NEEDS REPLACED OUR THE DIREC DRIVE NEEDS U JOINT.
Posted on Jul 03, 2008
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
  • 78 Answers
SOURCE: Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Posted on Jan 14, 2009
  • 6 Answers
SOURCE: Found oil and grease under washing machine. Makes loud noise when on spin cycle.
The oil and grease is probably from the transmission and yes you might be able to replace it. Get your make andmodel number and go to www.repairclinic.com. It is a very good site for finding pictures and parts of appliances. The parts are as cheap as you will find them. If the oil/grease is from the transmission, it will eventually fail. Fix it now or fix it later. Your choice.
Posted on May 30, 2009
Oil inside tub after spin cycle coming from gear shaft
IHAVE THE SAME PROBLEM IN MY FRIGIDAire washer dryer stach top loaded machine, the oil and smell of oil comes after finishing spin , do you have a solution because I called the company dealer in my country and they want 400 dollars to fix it, I think they are steling coz the machine is working and spinning but only little oil with smell come at the end of the washing.
any help
thanks
May 07, 2011 | Frigidaire FWS833A Top Load Washer
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
The tub won't drain and it spins very slowly. I've also noticed, over the last couple years, some oil/rust spots on my clothes. It is a top loading washer that is over 20 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 13, 2010 | Amana Washing Machines
Grease oil ring around tub and it smells like oil?
The only place there is oil in a washer is inside the transmission. If you have oil in the tub (and it didn't come from the clothes you put in) you have a bad transmission seal. It is generally cost prohivitive to replace the transmission. It's time to get a new washer. Look into the front load machines which use much less water and spin out twice as fast as top loaders. Some even have direct drive, which means no belt, transmission, or clutch.
Jul 19, 2009 | Washing Machines
Washing machine stains clothes
You can pull the agitator straight up and off to check if there is any grease / oil on the bottom of it. You may have to use a belt or similar item to slip under the agitator and attach the other end to a broom handle to pull up if it is difficult to remove. If there is grease / oil, it is not very easy or inexpensive to repair. The average life of a washer is about 9 years, so this one doesn't owe you anything. I'd look into a new front load unit which uses much less water and spins clothes out at 2X or more the RPM's of your current machine. Please don't rate this solution as anything but a FixYa rating will lower my overall score. Thanks.
Nov 19, 2008 | Washing Machines
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Top Load Washer
there is a drive belt from motor to drum but unlikely it needs tightening but possible. possibly a motor fault - try to identify where the smell comess from
Mar 20, 2007 | Whirlpool LXR9445JT Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
1,127 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
