Question about RCA F27669 TV
Smoke out of TV
I started the TV and some smoke came out of it. Since then, it doesn't turn on at all. I really want ti fix it, what should i do?
    Novelist:
    Scholar:
  • 148 Answers
My father used to have a saying, "All electronics run on smoke, you let the smoke out of them and they don't work anymore" Televisions are one of the most complicated devices ever invented by the hand of man. Modern sets seem simple due to the chips that perform very complicated functions. I would suggest finding a local repair technician that has access to the parts your set may now need and the test equipment required to track down some of the more difficult problems that occur in televisions.
Posted on May 17, 2008
My Chevrolet Astro Van 1998 is exhausting BLACK SMOKE on starting. What could be the cause and solution. PLS HELP
Well over here in ireland when this happens it usually means that you engine need ti be cleaned.
There is two ways of doing this one is to leave it in for a full engine clean.
The other way is to get it out on the motorway and drive it extremely hard till you see a puff of smoke from it then it will take off very fast which means it is cleaned out.
Jan 13, 2017 | Chevrolet Cars & Trucks
Engine smokes after start up for 1-2 min.
Depending on engine mileage, could be bad valve guide seals (high mileage) or PCV system issue. If seals, these can be replaced without removing cylinder heads.
Dec 15, 2014 | 2004 Dodge Dakota
Is it worth trying to fix
wow, those bearings must of got really hot,, replacing the bearings is a very cheap job if you do yourself, if you think you can tackle doing them, go for it
Sep 12, 2013 | Fisher and Paykel Washing Machines
2000 elantra white smoke during speed, doesn't start
White smoke normally indicates steam, did the car overheat ????...if it overheated check hoses for leaks,,,, loss of water etc
Jun 13, 2013 | 2000 Hyundai Elantra GLS
Car wouldn't start, but when it did it was smoking
One thing used many mechanics for diagnosis is: What color was the smoke?
White smoke usually means the engine is failing, and can indicate a leaking head gasklet, a cracked block, or a cracked head. This color smoke is from water and/or coolant getting into the cylinders.
Black smoke indicated too much fuel, and the engine may be "flooded", indicating a less expensidve fix.
Grey smoke indicates oil smoke from worn rings or worn valve stem seals.
The white smoke says you should have someone look at this really quickly to see if immediate attention is needed.
Be blessed
Jan 28, 2013 | Cars & Trucks
My 2000 Saab 9-5 2.3T occasionally smokes a decent slightly see through cloud of white smoke on cold starts, but for the rest of the day it doesn't do it. It also has been emitting a very small cloud...
White smoke usually indicates water could be a head gasket. Blue smoke when started and between shifts could be valve seals. usually expensive to fix.
Oct 05, 2017 | 2008 Saab 9-5
Ill turn on my car and it won't start unless my foot on the gas. It will turn on here and there. As soon as it turns on it throws black smoke and a terrible smell like gas mix with alcohol. I change the...
Black smoke is usually a sign of the accelerator pump set wrong, a choke plate could be partially closed and it could also be a really clogged air filter. If you pulled the air filter and the car turned on with no problems then replace it as this is one of the reasons for black smoke. It's not often a gas vehicle blows black smoke. The vehicle is starving for air.
Regards, Tony
Apr 20, 2011 | 1997 Mercury Grand Marquis
My kia sportage diesel is puffing blue smoke.
Nothing to fix friend. See, in diesel, when cold, there is an electric plunger on the throttle that speeds the idle a bit till warm up. Connected to that same wire is the cold start/temperature sensor. When cold/cool this sensor will excite the plunger to speed the idle, and put more fuel into the engine making the smoke you see, until warm up is reached and the sensor shuts down. You really don't have a repair needed friend.
Oct 03, 2017 | 2002 Kia Sportage
Canon Ixus 900 Ti started taking bad pictures
Smoke out of the speaker holes when the flash fires is just collected dust burning off no problem
Sep 18, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
TI 84 cant turn on
Sounds like your pc had a static charge that it discharged to your TI and that it fried something inside the TI. No warranty, No fix. You gotta buy a new one.
Apr 10, 2008 | Texas Instruments TI-84 Plus Silver...
RCA F27669 TV Logo
271 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
