Question about Behringer XENYX 2442FX Mixer
Im having distortion problems on my microphones, how do I activate the compressor on my mixer?
  • Behringer Master
  • 5,603 Answers
You can't activate something you don't have. The XENYX do not have compressors built in.
If you are getting mic distortion you are not properly setting up the mics.
You one at a time press the PFL down and have someone yell at the mic the loudest they will ever be. You adjust the trim control for that mic to be below the clip on the LED display. The you turn that PFL off and go to the next mic.
From that point all mic adjustments are from the slider. If you can't get enough gain, then back off ALL the other non-mic inputs and crank up the main slider and/or the power amp gains.
You have to learn to balance all the gains.
There are instruction videos on YouTube under "Soundboard".
Posted on Sep 16, 2010
The XLR-input distorts very fast
XLR inputs often have a pad (attenuator) that is switchable for signal level.
May 23, 2017 | Boss Rc 50
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
Oct 18, 2017 | Behringer Europower Pmp5000 Powered Mixer...
Yes i have a mackie onyx24.2 im trying to conect some compressors into the chanel insets. but when i plug it in it shuts the sound out... what's the problem?
Sounds like you've got the compressors etc. set wrong. Try connecting the tip and ring of a jack and putting this into the insert socket, if this works then it is definitely an issue with the settings on the equipment being inserted, if it does not work the mixer is faulty, but this is VERY VERY unlikely as all you are doing is inserting and there is nothing that could affect all channels unless they've forgotten to solder something on every channel.
Jul 02, 2012 | Mackie Onyx 24.4 Mixer
Hi im using the carlsbro gd 4000 in a 3 piece rock and roll band we are using an oldmike shure c606 and we cant get any volume out of the mike and its distorting the vocals we dont know whether the p.a.s...
Proper placement of mics versus the speakers of a PAS is important to avoid feedback. Your speakers need to be toward the audience from where the mic is. If the mic can "hear" the speakers you will likely have feedback. The mic should work even though it is a consumer grade mic.
WORD OF CAUTION: There are a LOT of fake SM58 microphones being sold... even on Ebay... SOME are fairly high quality and others are not.
Mar 31, 2011 | Music
I get a distorted sound from my speakers throug a Phonic Helix Board. It is connected on a PC through Fire Wire. The distortion is also there while using microphones or other inputs (CD-players etc.). It...
Hallo landgenoot ;)
It seems it is a power supply problem; distorted sound, no meters, solo buttons not working, headphones low level and distorted. One of the power supply voltages might be too low or even missing. The Helix series mixers use mainly 4 supply voltages: + 15 V and - 15 V for the analog part (audio), + 5 V for the DSP and logic and +48 V only for the phantom power. If for example the + or - 15 V is too low, clipping of the positive or negative parts of the waveform (dependng on which voltage is too low) will occur. If possible, first measure the voltages coming out of the power supply. You could use a metal part of a jack as ground reference.
For the FireWire board an extra voltage supplied by the switched PSU is used. It is specified as +12,2 V, but I measured 14 V. This voltage is lowered to + 5 V by a resistor on the FW board and a 7805 regulator. (Not very efficient!) But as far as I can see, the FW voltage is not the problem here. I have some service documentation of the Helix series mixers (12, 17 and 24, so if you need more you can conatct me: frankdevries [at] versatel.nl.
Groeten, Frank.
Mar 18, 2011 | Phonic Helix18fw 18 Channel Mixer with...
When i record thru my mxl genesis mic with the mixer i get like a loud distorton. Im using magix 14 ,and i have downloaded the audio driver off the disc that came with the mixer....Help
It is likely you do not have the levels set correctly and are over driving the mixer. Reduce the trim settings using the PFL buttons and monitor the level indicators to insure you are not clipping.
With a condenser mic you CANNOT have any speaker in the room that the mic can hear of course. These mics are so sensitive. Your mixer and monitor speakers and recording will be in a separate room from the soundproof studio typically.
To monitor the system anywhere in the same room as the mic you MUST use headphones that do NOT leak sound or you will get feedback and distortion.
Mar 14, 2011 | Behringer XENYX 2442FX Mixer
I am having problems with the effects. I cannot get any effect from it now. Please, help!
Make sure that BOTH the FX gain at each channel you want the FX on AND the "FX to Main" gain are turned up. Also when you select an effect push in the selection knob to activate the selection.
Jan 21, 2011 | Behringer Rx 1202fx 12 Channel Line and...
How do you hook the i pod up to the machine, we cant seem to figure it out?
You would have to get a 1/8 inch to dual RCA plug stereo SPLITTER cable and connect to the jacks on the back.
You will be disappointed however, as the unit will disable the microphones when you send music into the jacks... The thing just acts as a straight amplifier in this mode.
The only way to have a microphone active AND the IPOD is to sacrifice one microphone and use a mixer of the IPOD stereo output into a mono line into one of the microphone jacks. You can build your own mixer by using a couple 1K ohm resistors from each of the IPOD's output (stereo) leads into a single plug to plug into where one of the microphones plug in. You cannot tie the two leads from the IPOD together or each side of the stereo would fight the other causing distortion, hence the resistors prevent this.
Dec 29, 2010 | GPX Karaoke Party Machine
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
I have behringer xenyx802 Iam urgently looking to buy a wireless headphone and mic for my mixer and skype which I use for podcasting. The headet must be padded both ears and mic over mouth due to me being...
Here is a link to what your looking for,
http://pro-audio.musiciansfriend.com/product/Yamaha-CM500-Headset-with-BuiltIn-Microphone?sku=245012
I can't tell from the add but hopefully it comes with adapters for both plugs that will work on your mixer. It does have the one for the headphones but the one for the mic is not clear, they are not interchangeable.
You would obviously plug the headphones into the headphone jack. The knob labeled "Phones/Control Room" will control the volume without changing what's being broadcast. What you hear in you phones is exactly what you are broadcasting.
The microphone needs to go into either mono channel 1 or 2. The adapter for it needs to be a mono Tip/Sleeve adapter as the more common stereo Tip/Ring/Sleeve adapter may cause some problems. You can tell the difference by looking at how many sections are on the plug divided by a little black line. Two sections is mono, three is stereo.
Adjust you microphone level by setting the volume knob, the one on the very bottom, to the 12 o'clock position. Then turn the gain knob, the smaller plastic one on the very top, until the desired volume is reached. If you experience any clipping or distortion turn the gain knob down until it goes away. These are general settings, you may want to experiment until you get the best level without noise.
Nov 30, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer XENYX 2442FX Mixer Logo
148 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
