Question about LG Cell Phones
I never placed anything in the earjack but when I press the volume key on the left side of my Verizon LG VX 8360, it displays "Earpiece Vol-Earjack" instead of Master Volume. I cannot hear callers and they cannot hear me. I also cannot hear voicemail although my phone still has the capacity to ring and text. I believe the phone thinks I have something plugged in even though I don't and there appears to be no manual way to fix it. I've tried everything. please help!
  • 54 Answers
On most phones, the copper contacts down inside the jack work kind of like switches to detect if you have anything plugged in. Other stuff getting in there can depress the contacts, making the phone think something is plugged in.
Get a bright light (flashlight or the like) and shine it down in there. Check for anything unexpected in there, like pocket lint. If there's anything in there, fish it out with some small piece of wire (a paperclip, needle, or the like).
Posted on Sep 16, 2010
  • jfcummin Sep 16, 2010
    its now 5 hours later, and i think it would work better if i throw it as hard as i can on the freakin sidewalk. thanks lg and verizon
How to undo earphone/earjack for cell phone
You may be having a faulty earphone jack... try plugging in and out... then restart your phone and reset it
Jul 25, 2014 | Verizon Communications LG enV Cell Phone -...
My orange env1 has no earjack in it and when i call people i cant hear the sound because it is sending the sound to the earjack...which isnt in the phone...so i can call people but i cant hear them
Just make a jumper from the jack , on the ear peice point , one wire should be connected to ground and otherv one on the head phone jack , it will need some expert skilling
May 21, 2010 | LG enV VX9900 Cellular Phone
LG enV earpiece and key sound not working. Got the phone 3 weeks ago. No damage at all; hasn't been dropped, water damaged or anything. Worked fine yesterday. Sound settings are fine. Ring tone works and...
go to tools and setting --> sound settings --> keypad volume...see if you see "KEYPAD VOL-EARJACK"...that means that your phone is stuck in EARJACK mode....get a wired ear piece, plug it in, make a call, and then unplug after you end the call....that should resolve your problem...
Mar 12, 2010 | LG enV VX9900 Cellular Phone
No sound--master volume says ear jack
i put it in the freezer, hit it, drove a nail into the earjack port. then i poured water into the earjack port, held a lighter to it, and blew into it, none of that worked, so i jammed a paper clip into the earport and that fixed it. i also slammed in on the ground a few times.
Mar 02, 2010 | LG VX5500 Cell Phone
The keypad volume is stuck on earpiece & I can't hear without earjack how can I clear cell?
Called Verizon. Removed battery while phone is still on. They also had me update the phone via *228, option 2 but I don't think that helped.
Jan 22, 2010 | Verizon Communications LG VX8350 Cell...
Hi yes im having trouble with my lg chocolate, i cant hear or talk to the person but the call has gone thru
When the call has gone through, try changing the volume. If it says "Earpiece-Earjack Mode", the phone 'thinks' something is plugged into the data/charging port. Try using a clean toothbrush with a very small amount of alcohol on it (90% isopropyl is best) and brushing the port vigorously. If using 70% alcohol, use dust off or someother cnned air to dry he port out. If you are still having he issue, damaged is inside the phone and probably can't be fixed.
Oct 21, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Need to adjust earpiece volume
You can increase the earpiece volume by pressing the UP volume key (located on the side of the phone) *during* a phone call. I simply called my voicemail and once it connected, I hit the UP volume key and the volume meter displayed. Then I pressed it til it was the max and pressed SET. That worked for me, hope it works for you.
--Edriss
edriss@yahoo.com
Aug 17, 2008 | Cell Phones
LG enV VX9900
I would suggest returning the phone to verizon for replacement, if you are still under the 1 year warranty you should have no problems with a replacement.
Nov 28, 2007 | LG enV VX9900 Cellular Phone
Volume is non-existant on LG VX 4400
When you press vol up & down it will indicate "ringer ear jack." This means the phone is stuck in ear jack mode expecting a wired head phone accessory. Remove the battery then unscrew and pull out the antenna and the black plastic sleeve. Then remove the for small torx screws and carefully remove the back. Take a tooth pick to the back of the ear jack an bend the retainer pin back. Put everything back in reverse order and it should work fine.
Nov 28, 2007 | LG VX4400
Cell Phones Logo
311 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
