Question about Panasonic Lumix DMC-FX7 Digital Camera
The lens on my panasonic lumix dmc-fx07k camera will not open or extend out. when you turn the camera on it sounds as if it is in the process of opening and coming out, but it does not.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
Camera lens shutter does NOT OPEN!
Seriously this is not worth payi.g to fix unless you paid serious money for the camera. The shutter is also mechanixally tripped by the shutter button. Its a electrical charge that connects to the processing chip inside.
Jul 15, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera says turn off and turn on panasonic lumix dmc-fs5
While you are turning the camera on, hold the lever which you use for zooming in. The lens should extend before you get the annoying message about turning the the camera off and on. Then, gently apply pressure to the lens as if you wanted to push it back to the camera. While you are doing this, turn the camera off (lens should come back into the body of the camera). This will solve your problem.
Thank you!
May 17, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Lens stuck
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 22, 2007 | Panasonic Lumix DMC-LC43 Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
257 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
