Question about Husqvarna Designer I
I just got a new computer with windows 7 in it. When i try to install the 3D software it doesn't work with windows 7. what can i do to get my program to work. When i install it it causes some of my programs to not respond.
I just purchased a gateway window 7 lap top, and i have a designer 1 husqvarna embroidery machine. my problem is that I can't down load the program on to my lap top . It tells me
Incompatibity with 64-bit version of windows, for me to ask for a 64- bit windows compatible verison. AS YOU CAN TELL I AM NOT GOOD WITH COMPUTERS. IM VERY NEW AT THIS. PLEASE EXPLAIN IN PLAIN ENGLISH. THANK YOU
Clara
Posted on Jun 16, 2011
  • 201 Answers
3D can be made to work with Windows 7 - I have it working just fine on my 64-bit Win.7. Go to http://www.sewmuch4retirement.com/tips.html
Tip No.4 from the top is for you - these are the instructions I followed and they worked perfectly. You do need to be sure you have the latest version of 3D - it's 7.25 I believe.
Posted on Sep 26, 2010
Dongle won't work
did you try the dongle in another port... yes if you can find the patch you can load it onto a flash drive or sd card and then upload it over to the new pc
Dec 28, 2013 | Husqvarna Designer I
Loaded 3D Embroidery software on computer but will not recognize the dongle plugged in to the usb port. Drivers for dongle did not automatically load, went online to find a HASP file (driver I think) and...
1st try another usb port
2nd uninstall the software and plug the device in only after you have reinstalled the software and you are asked to plug it in. If it doesn't ask then install the software first and try again.
You can also right click on my computer and select manage.
then on the left side of the window select device manager, unplug and plug back the usb dongle and see if any devices appear or disappear also note any yellow ! marks. you may have to press the scan for new hardware button or right click on the window to scan for hardware changes.
Jun 18, 2008 | Husqvarna Rose
Can I run 3D Embroidery for my Designer SE on Windows 7?
Nope. your choices are as follows.
1. have your computer partitioned with Windows 95 and Windows 7
2. buy a second hand computer with the older windows version.
3. Buy the new version of the software.
Aug 02, 2012 | Sewing Machines
I have 3D Customizing and the newer reader/writer. The dongle works. The reader/writer is not found is what Customizing says. I have Windows 7 - any help will be greatly appreciated. Thank you.
3D will not run properly on a Windows 7 computer.The USB reader/writer will work fine with 5D software.
Trust me, I have tried extensively to get 3D to run on Windows 7. I ran it on Vista, for a while. Then an update to Windows ended that. I've never had it function normally on Windows 7.
Sep 12, 2011 | Husqvarna Viking 1
Just bought this machine and installed the software. When I try to use I get a message: Can not run CF_Splash.dll
It sounds like you are trying to use the software on Windows 7 or Vista. There's a patch at www.Futura-support.com you'll need. On the lefthand side of the screen, click on downloads, then choose CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. Be sure to install ALL Futura software you've already installed and reboot your PC BEFORE starting the new instructions.
If for some reason this still doesn't solve your problem, I've posted a solution that's a bit more involved on the CE100 Problems & Solutions home page for running your machine on Windows Vista/7. Basically, it allows you to run any XP program on Windows Vista or 7 using your old XP software. The Futura patch works for most people, though, so you will hopefully not have to go that route.
Happy embroidery!
Feb 15, 2011 | Singer CE-100 Futura Computerized Sewing...
My computer with Windows XP is on it's last leg. I have 3D software. Is there a fix available for 3D software and Windows 7?
Yes. Go to this website:
and follow the Tips link - I think it is tip No.4 which gives precise directions on how to get 3D working on Windows 7. It worked for me.
Oct 23, 2010 | Husqvarna Designer I
I have recently bought a new computer and i installed the software, but the machine will not recognise the computer, can it be installed on computer with the new windows 7 or do i need an update??
Yes, it can be installed on Windows 7. Check the Futura support sight at www.Futura-support.com and look on the right hand side under downloads. There's a download listed for CE150/250/350, etc, that applies to XP 32 & 64 bit, Vista and Windows 7 32 & 64 bit. Follow the directions CAREFULLY! If this doesn't work for you, I've posted a set of instructions under CE100 solutions for running the CE100 software on Windows Vista/7 by installing a Virtual Machine software on Windows 7 that works regardless of the situation.
The update should work for you perfectly, however. Just make sure you uninstall the Futura software and reboot your machine BEFORE you do anything else and follow the instructions from the website carefully! Good luck!
Jul 29, 2010 | Singer CE350
Designer I: I just bought a new computer with Windows 7 and ca...
I hate to tell you....it's software upgrade time. You need 4D or later to run on "7"
May 17, 2010 | Husqvarna Designer I
I need a driver for a husquvarna 3D reader/writer card, where can I find one
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Dongle issues - http://www.husqvarnaviking.com/global/8588_4197.htm
Good luck.
Dec 10, 2009 | Husqvarna Viking 1
Sewing Machines Logo
274 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
