Question about Belkin (F5D7230-4) Router (587009)
Router disconnection router works fine with wireless connection to my laptop; when my daughter comes home, her laptopknocks off my internet connection. How do we resolve this?
  • Belkin Master
  • 6,487 Answers
1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
2. You will get a login page. Leave the password blank. Click Submit .
3. On the left side of the page, click Channel and SSID below Wireless .
4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel like 11. Click Apply Changes .
5. Click Logout in the top right hand corner.
6.Then reconnect to your wireless network.
Posted on May 17, 2008
Everytime my wife's iphone connects to our home network, my laptop looses the internet connection and goes to a local connection only. I have to disconnect and reconnect and everything works fine.
I find that when it comes to iphones and home wireless networks, that using 64bit encryption is the best. I'm not sure what you are using now, but give this a try.
May 03, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My daughter works at home as a Customer Service Rep. for Generation Networks (Ancestor.com). She has a terminal from work and it is configured for her to work from home. She has done that for over a year...
This is only a problem with the firmware of your modem/router that you need to update it, because a network device like a modem and router that is working fine for severla years and suddenly stop working you just need to update the firmware of it and it should be working fine again, to update the firmware of the modem/router just need to call the manufacturer for that....
Hope that helps.........
Oct 05, 2008 | Computers & Internet
Laptop cannot pick up wireless from modem
Is your Wireless router integrated in the modem? If it is not, try to unplug the router for a few minutes then restore the power and see if it fixes the problem. If it is integrateddo the same for the modem. Try to connect using the laptop. If it does not work use the laptop to scan for new wireless locations and make sure you see the home location. If you do not your wireless router is not working, If so select the home location and enter any Web Encryption Protection and try to connect. If your wireless router is not working, make sure the preference for the router has the wireless function turned on. To do this use ether the software which you received with the router/modem or internet explorer to access the IP address of the router. If your router is configured for wireless use it may be a bad wireless router.
Feb 05, 2010 | NetGear CG814M (pn-3201155) Modem
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Unable to get wireless connection at a new location
Hi...
Verizon uses PPOE(point to point protocol over ethernet) and Comast does not use PPOE. Therefore she needs to get inside the router 168.192.1.1(user:admin & pdw: admin) to disable the "PPOE". Oh and also, the router needs to be hard wired to the computer for reconfiguration to take place...hope this helps
May 18, 2009 | Linksys Wireless-G WRT54G Router
Home computer is connected but cannot get laptop to connect
If your router has a password, it needs to be typed into the other laptop, also the router may not be giving out enough IP addresses, so go into the router configuration (usually on the computer that can connect to the internet by typing 192.162.1.1, or 2.1 or something similar usually ending in .1 , into the address bar (where the www. goes) in internet explorer. Explore those settings a little, be sure to disable anything you see requiring security or and kind of filtering (wether it be IP mac address, etc)
Also, make sure that your laptop can connect with the router in the first place. If it can't then there could be an issue with the laptop, like you could have a wireless N router, and your laptop may only have a wireless A card (which wouldn't usually work).
I hope this helps somewhat.
Stay spicy and happy lappying :)
Dec 14, 2008 | Computers & Internet
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
How to get a third computer to work on my wireless network
is the adapter connected to the router? are you using wep? is the firewall disabled?
Nov 11, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Netgear wireless adapter
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Belkin (F5D7230-4) Router (587009) Logo
106 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
