Question about Kenmore Oasis HE 27082 Top Load Washer
My top load , kenmore oasis elite washer, worked perfect for about three years. now when it comes to the final high speed spin cycle it abruptly stops and shows code UL. it will do this with large load,small load or no load at all. the machine is perfectly level on a wood floor.
  • 15,935 Answers
It appears your load balance sensor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
How to by pass the lid lock switch on a Kenmore elite Oasis HE washmachine
Not a real good idea except under emergency situations, as the lid lock is a safety switch to prevent access to the washer during spin cycles when the drum is operating at high speed and you don't want foreign objects (like hands) coming into contact with a high speed rotating drum or its contents. If you have the unit open enough to cut the wires, you had enough access to replace the switch, which you can get at SearsPartsDirect.com or any Sears Service Center in your area. If you are hell-bent on operating the machine in an unsafe condition, just connect the bare ends of the wires with a wire nut, which will perform the same circuit connection as the closed switch. Tape the connected wires away from any moving parts, don't let any bare wire come in contact with any metal and keep the lid closed during all parts of the wash, rinse and spin cycles.
Jul 25, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
199 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
