Question about Sansui HDLCD3210 32 in. LCD TV
TV has audio but black screen - Sansui HDLCD3210 32 in. LCD TV
  • 11,361 Answers
Unplug it for about an hour to let it reset itself to see if it will work again, otherwise you may have problem in the 24vdc power supply or the backlight inverter board, those are the two areas you need to check frist.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Sep 16, 2010
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Screens nturns black but have audio
Ur video board is dead.Or the video socket connect to the CRT(tv tube) is cold solder.
Sep 06, 2009 | Sony KV-27V40 27" TV
My HT3061P Prima tv, has the black screen, but the audio is very good.
adjust first the screen. it is a knob at the back of plyback.(lower knob),if the has vertical line ,then the section had a problem.try to resolder the vertical IC or else change the IC.
Oct 15, 2008 | Prima CV2011 TV
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Sansui HDLCD3210 32 in. LCD TV Logo
97 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
