Question about West Bend (59055) Stainless steel 60-Cup Coffee Maker
Need to replace my spigot on my 30 cup revere ware coffee maker because it leaks. Where can I get one to "pop" into that hole so I can pour the coffee out of the pot into the cups.
I have a Westbend 24 cup coffee urn with a leaky faucet. I tried finding areplacement spigot for it but so far no luck. My spigot has a screw in the top that allow for disassembly. It looks to me that if I could get a replacement rubber O-ring I could fix it myself. Does anyone know where I could get this?
Thanks
Kelvin
kelvinlov@gmail.com
Posted on Mar 07, 2011
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
My Waring Pro Coffee maker leaks water out of the bottom. In the morning when I get in I have to clean up the leak. Is this repairable?
When you pour water into the screen area it travels toward the back of the unit and drops through a rubber gasket/cup to be heated/processed. I have the same problem and while I bought another WC1000 I took my old one apart. By turning it over and removing 4 recessed screws you can carefully lift the top off (carefully because wiring is attached). However, you can now access the rubber gasket/cup. Doing this I found that mine was torn which I must assume is the cause of the leaking problem. Now if anyone knows where I can get a replacement rubber gasket/cup or a part number I would appreciate it.
Aug 22, 2010 | Waring Pro WC1000 Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Whay is the coffee to water ratio per cup?
I have the Regal 10 to 30 cup model K7030C.
Instructions read as follows:
CUPS COFFEE
(5-oz serving) ( 8-oz dry measure)
10 ........................2/3 Cup
20.........................1 1/4 Cups
30.........................1 3/4 Cups
Hope this helps
Mar 06, 2009 | Regal Ware (RW58230R) 30-Cup Coffee Maker
One dispense spigot barely trickles
You need to take a paper clip and clean the little holes where the water comes out on the left side (It's like a screen). Also you should pull the silver thing that adjusts to allow taller cups underneath up and down several times. You should do the latter every week. It helps get rid of some of the coffee grounds that block the aforementioned little holes.
Oct 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Vintage Revere Ware Copper Clad 8 Cup Drip Coffee Pot
Barbara,
Coffee grounds go in the top. (i use a filter paper also.) Install baffle with stem up. Assemble top to empty bottom section. pour boiling water into top. I use 4 cups water, 2 scoops chickory coffee. Let water trickle down into bottom. I put mine back through 3 times, black as tar. That is the advantage of this machine. I will never use another.........
Mar 11, 2008 | Kitchen Appliances - Others
Where to find cord for westbend 30 cup coffee maker - 58030
Hello!
You can ask you vendor about that. else they can tell you where to buy that cord or the can suggest a possible soltuion.
best regards, melnavz
Mar 03, 2008 | Regal Ware (RW58230R) 30-Cup Coffee Maker
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
West Bend (59055) Stainless steel 60-Cup Coffee Maker Logo
276 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
