Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Our whirlpool cabrio is just 3 years. we have a problem that make it always in a "F#_ MODE... please help us to reset
  • 23 Answers
F code on a cabrio wtw6400sw3 sounds like a bearing is going out
its not an f code its an f code then u have to add the applICABLE NUMBER THAT APPLIES.
SEE THE LINK Whirlpool Cabrio Automatic Diagnostic Mode
Here are instructions for entering the technical diagnostic mode. This mode is designed for service technicians familiar with the product testing operation, if you need more instructions, you can find information on the tech sheet located inside the console of the washer as the entire diagnostic process cannot be published on this site. Always disconnect power supply before entering any closed section of the appliance and wear safety glasses and gloves.
1.Be sure the washer is in standby mode (plugged in with all indicators off)
2.Perform the following sequence of movement using the cycle selector knob.
3.NOTE: AFTER RESET, sequence must be completed within 6 seconds.
4.RESET - Rotate cycle selector knob counterclockwise one or more clicks to clear sequence.
5.a. Rotate cycle selector knob clockwise one click and wait ½ second.
6.b. Rotate cycle selector knob clockwise one click.
7.? Successful activation of Diagnostic test modes will be indicated by all status LEDs (except for Lid Locked) flashing ON and OFF in half-second intervals.
8.NOTE: LED names may vary between makes and models.
9.If the status LEDs do not display as described above, the sequence may not have been completed within 6 seconds. Repeat step 2 to ensure this was not the cause Whirlpool Diagnostic Mode
Dec 31, 2016 | Washing Machines
I have had the machine repaired 3 times now it
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Jul 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio is displaying F51 what is this
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. If you google whirlpool cabrio error code F51, you'll get an idea of what you are up against. This is obviously a manufacturer's defect. They should take care of this problem whether you are in warranty or not. If you are insistent, maybe they will. Contact whirlpool directly if you're not satisfied by your local service people. This is not a DIY job.
Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer won't start
If unplugging the washer for a few minutes does not reset the main control then the electronic control board is likely shot but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
This will help: Repair Manual - Cabrio top loading washer
For Whirlpool Cabrio washer parts CLICK HERE
www.RepairClinic.com
Feb 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio top loader,always having to "reset" 2 times 1 cy
Hi Curtis: File a class-action suit against the Whirlpool company. There is something wrong with the electronic module that tells the washer to shut down during the rinse cycle.
If you pause, lift the lid, pour in about 3 gallons of water into the tub, close the lid, push start, the washer should continue without having to wear out your fingers pushing the buttons. The buttons will eventually be pushed down into the control panel and you will have to use a pencil to reach them.
Also helps to have a nice cool bottle of regular beer (not the light stuff) before you start the load, the washing duty will work out much smoother. Good Luck.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Dl error will not clear
My Whirlpool cabrio is making a humming noise an the water filled the tub but wont drain i tried pressing buttons but no luck please help,how do i reset it
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Fault
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
If you still cant fix it come back here..and ask i will help you out..
And please dont forget to rate if its solved..
Oct 20, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
