Question about Cell Phones
Having a hard time removing cell phone battery cover
Having a hard time getting battery cover off a cell just purchased on line
  • Anonymous Mar 30, 2009
    Can't get the back off. I'm going to bring it back and see if they can do it. It looks like the sides were not cut properly and therefore are a solid piece. Pisses me off. It was a hassle getting the phone.
    Genius:
  • 2,035 Answers
Model number of the phone.
Posted on May 17, 2008
My phone has been unlocked but every time i turn it on is still says enter restriction code its a nokia 6700
1. Obtain the lock code for your Nokia 6700. You can purchase the lock code from a cellular unlocking service or get it from your cellular carrier. Some carriers have criteria your account must meet in order to give you the code, such as the account being active for a certain length of time.
2. Turn off the phone and remove the battery cover. Press the battery release button on the bottom edge of the phone, remove the back cover and lift the battery from the top. Set the battery and battery cover aside.
3. Slide the SIM card bracket toward the left edge of the phone, lift the bracket and remove the SIM. Close the bracket and reinstall the battery and battery cover.
4. Power the phone on with no SIM card. The phone will show a message stating no SIM is installed.
5. Type "#PW+LOCK+1#" with your lock code replacing LOCK. For example, if your code is 1234568, type "#PW+12345678+1#" on the keypad. Press the "*" key quickly three times for P, four times for W, and twice for +. For Fido or Rogers Canada, use "7" instead of "1."
6. Wait for the phone to show "SIM Restriction Off" and reboot. You can now use the Surge with any SIM card.
Aug 18, 2012 | Nokia 6700 Classic Cell Phone
Removing back from i-phone
Apple has made it impossible to easily remove the back of the iPhones. If you are not an expert in getting the cover off, then you WILL break it. The people who know how to do it have broken many phones in the process of learning. I'm not sure what exact problem you're having with the phone, but try holding both the lock and home buttons at the same time for about 60 seconds. This completes a Hard-Reboot and is similar to removing the battery and putting it back in. Hope this helps :)
Aug 22, 2011 | Apple iPhone Smartphone
E5 unable to start
1. Remove Battery, Attempt to Restart phone. repeat at least twice.
2. Contact a service representative of your carrier or take the device into your carriers store, most of the time they will recommend a hard reset and will attempt to backup your data, if you are still covered and they rules that it is not your fault for having a broken phone they may replace the handset.
Good Luck!
Jun 16, 2011 | Nokia E5 Cell Phone
Norstar phone displays you have a message yet there is no message. How do I clear the screen of this. Thanks for any help you can give me.
You can do what is called a hard reset. By having the phone on then removing the battery cover and pulling the battery out, leaving it out for a couple of minutes then putting it back in and turning the phone on.
Feb 15, 2011 | Cell Phones
I went in the sea with my phone in my pocket yesterday this was yesterday is there any hope 4 my g1?
Follow these procedure to save or revive your phone, remove Cell Phone from Water: Time is of the essence when it comes to saving a fixing a submerged cell phone, as soon as you see your phone in water, remove it quickly! Every second matters do this step quick.
Saving the Battery: In order to save the battery on your cell phone after it's been wet, quickly take the battery out of the phone as soon as you take it out of the water. Buy doing this you will ensure that minimal damage is done to your battery.
Drying the Phone Out: Quickly shake your cell phone to get all of the water out and reach for the paper towels. Press down on your cell phone to make sure all of the excess water has come out. If you have accessories such as cell phone covers, take them off promptly otherwise water will still be stuck in your phone.
Saving your Info: If your cell phone takes a SIM card, quickly remove it before the phone dries. While you may still loose some of your information, you won't lose it all if you take the SIM card out of your cell phone in time
.Removing Excess Moisture: To remove the unseen moisture in your cell phone you will need to cover it with either Desiccant gel packs or rice. Desiccant gel packs can sometimes be found when purchasing brand new shoes or clothes. Make sure your cell phone is completely covered with either one of these for up to 3 hours.
Vacuuming: Take your vacuum hose and place it up to 4 inches away from your cell phone with it on. While this won't remove all of the water, it will certainly eliminate the big spots of water damage.
Turing the Phone On: After allowing your cell phone to sit a day or two with the power off, turn it on to see if it works. More than likely if you followed these steps as soon as your phone was submerged, it will cut on. If not, you will have to purchase a new cell phone because the one you have can't be saved.
Take care.
Aug 08, 2010 | HTC G1
I call have water damaged what should i do ?
Take care.
Jul 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
Water damage how can i try an fix it? on a samsung gravity 2
Take care.
Jul 18, 2010 | Samsung Gravity SGH-T459 Cell Phone
My screen is black but when i press hard in the middle it turns on until i let go.
hello,
Your phone screen is having partial contact of the, i suggest you turn off, remove the battery cover, battery and sim card.
Turn your phone over and gently remove the front cover. It just pulls off and you can go on to tighten the LCD of your phone.
If it is still giving the same problem after this, i suggest you replace or change the screen with a better one.
Best regards.
Feb 07, 2010 | LG PCMICROSTORE Brand Rumor / Scoop /...
Removing Battery cover for cell phone
There are so many models out there and many different ways to remove battery covers.
Besdies the brand I also need the model of the cell phone in order to tell you how to remove the cover.
Try looking up the model from the place you purchased the phone from, if you purchased it online you most probebly can find the model number in the description of the listing.
Mar 11, 2009 | Cell Phones
Cell Phones Logo
1,077 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
