Question about Rinnai Webstone The isolator EXP tankless water heater Service Valves WRIK
I have a Rinnai R75LS and have it hooked up to clean with vinegar. However the R75LS will not allow the vinegar to flow through. I have watched videos etc. and seem to be unable to get the vinegar to flow through the system. What am I missing?
    Novelist:
  • 120 Answers
I'm assuming you heater will let water flow through and it's not completely blocked with scale. There is a motorised valve that needs to be open. Start with the heater connected normally and run a hot tap. While it is firing turn off the power, this will leave the valve in it's open state.Now connect up your heater to the vinegar supply; do not turn the power back on.
Posted on Sep 16, 2010
Is there trouble shooting instruction for a R75LS Rianni
I would contact the manufacturer to see if they can enlighten you as to what it might be .
Oct 09, 2016 | Rinnai R75LSe Natural Gas Tankless Water...
Rinnai R75LS error 12. I recently went to fill my bathtub and got nothing but cold water. After checking the hot water heater it was flashing 12. After looking at the book saw it meant flame failure. My...
You may have instant hots for the sinks, a small heater for each location which won't be on the tub. If there is a flame fail the hot water heater is not working. Check the flame sensor and ignitor.
Jan 07, 2014 | Water Heaters
What does it take to convert a Rinnai R75LS water heater from propane to natural gas?
Contact Rinnai.
Gas control valve is different, burner is different, burner and gas valve must match, threads are regular instead of reverse, dip switches probably have to be changed since combustion of NG is not as hot. Maybe different sensors. Pressures are lower with NG.
Mar 28, 2013 | Rinnai Water Heaters
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
When the hot water is turned on it makes a groaning sound and when turned off makes it again
how old is the Rinnai?
might have deposites formed preventing it from working properly
also check the inline water filter, this should be cleaned out once in a while
do you have the instructions?
might need to be flushed out. takes a little time about 5 gallons of vinegar and a small pump
I recently ran one through flushing, ran about 2 hours before it was flushed clean.
Aug 12, 2010 | Rinnai Water Heaters
Rinnai R50LSi water heater- Water doesn't heat.
Flow meters can get jammed by silt or debrise. The only way that I know to check this problem it to remove & inspect the part and that takes alot of training if you have a Rinnai (not recommended for the beginner).
One thing you could check is the inlet screen. Turn off the water and power to the unit and drain down. The screen in the black plastic circle on the inlet fitting under the unit. Unscrew this and check how much grit it has collected. Clean off, replace, turn water back on, open a hot faucet to get the air out then turn the power back on. This sometimes improves the flow enough to solve the problem.
Apr 16, 2010 | Rinnai Water Heaters
Rinnai R50LS- water doesn't heat, even though there is good flow.
If it's a new install: the water is going backwards through the heater and you need to check that your cold water IN is actually hooked up to the cold water IN spot on the heater. they don't register flow if the flow goes backwards through the heater.
If it's not a new install: something is stuck in your flow sensor, drain the unit and take it out to check.
Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Nov 28, 2009 | Rinnai Water Heaters
Need to wire a zone control for a closed system with a circulator
thats because the rinnai does not have a set up for a circulating pump it would make the unit run all the time,, they are not designed to work that way,, you will have to just wait for the hot water to get to the faucet just like before,,don't let any one tell you there is a way once the water flows it turn on the tankless so it would never shut off, you could get on that goes on a timer on say the farthest fauset away from the unit and set the timer to come on like 2 min before you are ready to use the water in that bathroom in the morning or at night other then that there is nothing else you can do
Jan 28, 2009 | Rinnai Digital Remote Water Heater Control...
Rinnai Webstone The isolator EXP  tankless water heater Service Valves WRIK Logo
678 people viewed this question
Top Rinnai Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
