Question about Whirlpool LEW0050P Dryer
Im trying to install a 4 prong power cord on this dryer it is orginally a 3 prong but i cant figure out where to instal the fourth wire the green ground wire
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 16, 2010
Tip
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards).
3-Prong or 4-Prong – The Difference:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
on Jul 16, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Just moved into an older home with a 3 prong dryer receptacle. My whirlpool duet dryer model: GEW9250PL1 currently has a 4 prong cord. I have purchased the 3 prong cord and am ready to install. Very...
Hi, White, green green/white striped they are all the same....only thing you really have to worry about is that you have the red and black in the proper places...
heatman101
Jul 13, 2011 | Dryers
I was given the dryer, and the cord unattached. I want to be sure I attach them correctly. The cord has three prongs and ther are three holes for attachment. Where should the grounding be atached?
For a 3-pronged cord, the ground (nuetral) is the middle wire on the cord and is attached to the middle terminal post. the outside wires are attached to the outside posts. It doesn't matter which wire goes to which side.
On 4-pronged cords, there is a fourth green wire that is attached the unit's case for grounding purposes. Which cord you use is dictated by what power outlet you have, 3 or 4-pronged.
If I can help anymore, please let me know.
Best, G
Aug 03, 2010 | Whirlpool Dryers
New house has three prong recpticle dryer cord has four prongs. Can I use a three prong cord and strap a wire to the fourth wire on back of dryer? If not got a solution?
If the new house has an existing three-wire outlet, the simplest solution is to install a 3-prong power cord on your dryer. The following link explains the differences between a 3-wire and 4-wire configuraiton:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
So...if you need to install a 3 prong power cord, it should be wired as follows:
RED (HOT) 120VAC to RED
BLACK (HOT) 120VAC to BLACK
WHITE (NEUTRAL) 0 VAC to WHITE - a Ground wire needs to be connected to the Neutral lead at the terminal block and grounded to the dryer cabinet.
The other alternative would require you to install a 4-wire receptacle so you could still use your current power cord. A certified electrician is recommended for this job and may cost you some money. A replacement power cord, on the other hand, usually costs less than $20 and can be found ay any hardware store.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 10, 2010 | Dryers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
Front loader whirlpool dryer (04') 3-prong cord; 4-prong outlet..
You'll need to get a new 4 prong cable. Connect wires as color coded now and connect the green to the frame.
Jul 16, 2009 | Whirlpool GEW9250P Electric Dryer
Whirlpool LEW0050P Dryer Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
