Question about E-Machines eMachines Desktop PC
We had a power failure in the nite my computer turned off.when i turned it on ,it lights you can hear the hd working ,no signal to the monitor someone said i had to clear the c mos?is this true and how do i do that
    Scholar:
  • 142 Answers
With the power off and everything unplugged, open up the case and look for a flat round battery the size of a quarter.
Pry it out of the socket. Gingerly. Use your fingernails if you can or a very thin blade screwdriver.
Replace it after 30 seconds.
Turn on your computer. Your BIOS settings will be reset, and you will have to do things like change your date / time. More than likely you will be able to use the default factory settings unless you have had to vary the boot order..... but that's probably another something to explore if this doesn't work.
Good luck !
Posted on Sep 16, 2010
How do I get my computer to turn on it is saying no signal?
1st, it is the monitor that says, "No Signal." That being; is the actual computer turned on?
If it has a green / red power light and you can hear the hard drive and fan running inside the computer case, then check the cable that runs from the back of your monitor to the back of your computer's case.
It may be disconnected of just bad.
If you cannot hear any noise inside the computer case or there is no power light on, then check the electrical cord in back of the computer's case to the wall. If that is good, check to see if there is a light switch that turns that socket on and off.
Jun 02, 2015 | Computers & Internet
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
No Monitor signal and no ethernet light on modem
please test the power source that the computer is plugged into and confirm it is working with a lamp or something.
If power source is confirmed working and the computer is plugged in and it is turned on and there is still no signal to the monitor and the ethernet lights are not on when the cable is plugged into it. Also check that all cables from the monitor to the computer are connected properly and secure. if the above has been done and still no signal then there are some Possible Causes
1. Mother Board failure (video card on motherboard is defective)
2. Monitor Failure (computer is sending video signal but monitor can not process it)
3. Video Card failure (if the video card is not designed into the motherboard)
Troubleshooting and repair
See if you can get access to another monitor to test the computer with to see if it sends he video signal ok to that monitor. If you can not get access to one then the only option is to get a video card and either you can install it yourself, or have it installed at a repair station.
If you purchase the card and install it yourself most stores will let you return the cards if they do not work or they are not usable. If you do go that route just make sure to ask about return policies prior to trying it.
I would really consider replacing the video card first you can get them from 30.00 and up and there is ony a few screw to remove to install them. Most of the video card manufactures also have tech support for helping people with the installations of the cards.
I would not worry about the lights on the modem or network card until the monitor issue is resolved so you can then see if it is indeed making a connection to the internet.
Aug 02, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
I have only a black screen other monitors work well.
I would try this monitor with another PC first, most common failures in the monitors after a couple years are failed caps in the power supply. Please verify first that it is not the PC problem, if it is, then please look through my pictures to get some ideas what to look for inside if you decide to DIY repair on you monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 20, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
When i turn on my computer all it tells me is sva no signal input please check video signal
sometimes the monitor could of blown or your graphics card has gone bad. first check and see if your graphics card still works. go to another monitor and hook it up if it works then your monitor has blown if it doesn't work then you have a graphics card problem.
Nov 20, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
My monitor says no signal
You'll need to check the cable connections and the computer that it is attached to. The monitor may be going into standby mode because the computer went into Suspended/Hibernate mode. Try restarting the computer. If you're unable to do this, try a hard power off and then try to turn it back on.
Sep 17, 2008 | E-Machines eMachines Monitor E15T4
Monitor not getting signal
Check your cables.
If the cables are fine then there is something
wrong with your comuter.
Do you hear any beeping sounds?
Mar 07, 2008 | HP Compaq d530 SFF PC Desktop
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
