Question about Vizio L32 32 in. LCD HDTV
Vizio L32. When in DTV mode DTV Tuner function comes up as a blank blue screen. How can this be reset?
  • bsoroos Sep 17, 2010
    After reading through the manual. I see that the only thing different from what I have been doing is connecting the antenna while the DTV is off. I'm now doing this but with the same results; a solid blue screen comes when I enter the channel tuning menu. I also assume that both of the digital antennas I've tried are working because I have used both of them successfully in the past. Any other thoughts on possible problems?
  • Vizio Master
  • 12,061 Answers
Hi, this is not something that can be reset. this Blue Screen is displayed as a default screen, whenever there is NO signal at the Input. You need to make sure your input connections are all 100% OK. The blue screen is displayed because the set cannot detect any input signals at all, you need to check, your antenna, and connections to it. In fact it would be a good idea if possible to test this outlet to see if indeed you do have a signal to begin with.
Below is your service manual below that is your user manual, use the service manual to troubleshoot this issue, use the user manual to ensure all settings are correct.
nationalservicealliance.com/visio/VIZIO-L37HDTV.pdf -
http://www.retrevo.com/support/Vizio-L32-TVs-manual/id/512dj084/t/2/
Posted on Sep 16, 2010
  • NotAvailable Sep 26, 2010
    I have a 2006 Vizio L37. When I turn it to DTV I get only a blue screen. This problem just started. Before whether I had an antenna hooked up or not the screen was black and it read "no signal" in the top left corner of the screen. I've solved this problem a few times by turning the TV on and off but that no longer works.
  • electronic & computer repair&  servicre
    This is because the problem that was intermittent before, has now gone "Hard On" as we say, the component has failed totally and this is the cause of there being no signal, as thats what that blue screen signifies, NO Input Signal, from either Tuner Or External. When the screen is black, that means it knows there is an input connected BUT there is NO actual signal on that input.
    It sounds as though either your Tuner/Input matrix and or switcher has faulted. This will have to be repaired.
    Often this can be a problem with one of the Power "Rails" to the Tuner and switching matrix, in any event, that's the first place to start troubleshooting, the Power Supply, as if this area isn't 100 A OK, nothing else can be!
    There is a link below for a service manual for your set. Copy paste this link into your browser to download it.
    http://webcache.googleusercontent.com/se... Vizio L37 service manual
What causes DTV mode to not work.
why do you want to use dtv mode anyway . if everything else works .
Oct 30, 2015 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio L32 DTV menu freezes
Hi did anyone replied to you? i am having the same problem. if you know any fix... PLEASE... Please .... let me know
Aug 29, 2009 | Vizio L32 32 in. LCD HDTV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
DTV Input
Well mine is now fixed.
$250 for the main tuner board and another hundred for labor.
I did find that there are some "like new" boards out there from otherwise damaged units. For instance a Big Box store damages a flat screen or exterior trim, the board is removed and tested.
The "like new" boards I found are about $150 with a 90 day warranty. The new board also has 90 day warranty.
The tech guy that posted here was correct. Thank you.
Aug 19, 2008 | Vizio GV46L 46 in. LCD Television
PIP
Let me know what you find out, I have a similar problem. I can get the PIP screen to come up but it will not allow me to have it on an input that actually shows a picture - just blue screen.
junk@slaing.com
Dec 31, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
1,623 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
